Results 1 to 15 of 15
Thread: Metal in the oil?
    VZ Exec
    Feb 2011
    Central Coast, NSW
    Default Metal in the oil?
    Hi All, first post so i hope i dont stuff it too much. How big a problem do i have, changed the oil this morning and after draining it back into the container i found a lot of small metal filings in the bottom of the oil drain pan. The motor is an alloytec. Currently has 111,000 on the clock.
    I change the oil every 5000 K with magnatec. Any help would be greatly appreciated
    I think i attached the photo o.k they are very small and a dark color, not shiny really
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    how big are these filings in the oil? maybe try a different type of oil as magnatec is a bit magnetic, not sure if it would change anything though...
    Spoken by a true member of The Committee
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Hmmm... not sure about what could be causing this specifically. Normal wear and tear.
    But, now that you have identified that there isan issue, you can get powerful magnets that you stick to your oil filter and they will trap any metal shavings that are going through your oil system.
    I would suggest looking into one of these?
    FilterMAG: Magnetic Oil Filters finish the Job Your Filter Started.
    Good luck.
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Jesterarts View Post
    Good luck.
    Will not work on Alloytec due to the oil filter setup.
    Attached Thumbnails Attached Thumbnails Metal in the oil?-b-pyf1wbgk-kgrhgoh-dyejlll5l7-bkdbsmmmmq-_12.jpg
    VZ Exec
    Feb 2011
    Central Coast, NSW
    I think that will work, They are very small and are a dark coloured metal not shiny really. i hope i have attached pics
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Good luck.
    As heyitsenricopallazzo said i dont think it will work on the alloytec due to having a cartidge oil filter setup
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VZ A4 Saloon
    Nov 2010
    Looks like nothing to worry about to me.
    Do they stick to a magnet (ferrous)?
    VZ Exec
    Feb 2011
    Central Coast, NSW
    May 2009
    Gold Coast
    hopefully not, what year model? i think the early 04 and 05 had timing chain problems that were rectified when the euro3 emmisions series vz came out
    VZ Exec
    Feb 2011
    Central Coast, NSW
    Sorry Richard been away for work no access to computer, yes its an 04 model.
    VB SL/E
    Dec 2008
    VZ SS
    Aug 2009
    Maitland NSW
    I wouldnt be overly concerned with them, bit of shit, but nothing to worry about. Make sure your funnel is clean when filling up.
    FG XR6T Ute manual
    May 2007
    Brissy
    Quote Originally Posted by VR38 View Post
    Maybe thrust bearing, is it manual?
    Thrust bearing? In the engine?
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
  15. #15
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by f1tzy View Post
    yes, stops crank shaft end float.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
  1. VT Metal on Metal scrap noise
    By VRNathan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2010, 06:15 AM
  2. Scrap Metal
    By Branch in forum The Pub
    Last Post: 16-11-2009, 07:05 PM
  3. What is this bit of metal?
    By centy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2008, 11:34 AM
  4. Metal allergy
    By Dayvo in forum The Pub
    Last Post: 13-08-2008, 10:23 AM
  5. VN Metal on Metal noise / Vibration
    By kerrin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2007, 03:48 PM
