Hi all.
Got a VZ Executive auto which has "POWER" mode off and is being driven like any normal car, to give you an idea it shifts up at around 2000-3000rpm, no higher than that.
However, my fuel consumption is NEVER below 13L/100km, I find this extremely hard to believe, so I reset the ECU (disconnected battery) and still get roughly the same. I've also had a service in the last 500km.
Any ideas why? My folks VE SS Manual gets around 14L/100km and gets driven pretty hard.
I get better economy out of my vz 6 spd SS 6 Litre than I did in my vy v6 and my VR v6.
Yep our vz exex alloytec gets those sort of figures,pos of a thing
Funny how i just got 9.9L per 100km and my avg is no worse then 10.6L per 100km
When you fall off the pace with the car you brought to the race, I'll be the one who's flying by you kickin' sh#t in your face
Could be ur oxy sensors.
What petrol do u use?
I just did my oxy sensors and it dropped from 18l/100km to 15l/100km @ an avg speed of 35km/h.
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
Which lambda/Oxygen sensors did you change. All 4 Or just fronts or rears??
It pretty much does the same thing as the fronts but it measeures your exhaust gasses after the cat converter to see how much is getting trapped by the cat. And measures the fuel mixture to ensure no harmful gasses go out the exhaust... I'm prettY sure
the after cat o2 sensors are only there to monitor the cat efficiency. i believe the front ones are what make a real difference to fuel con and performance. My vz ute averages between 12.5 -13.
@caprilicious honestly they shouldn't be used for performance or fuel consumption at all im pretty sure they are only used to see how much stuff is going through the cats for EURO 4 emissions laws
My advice would be to take them out and check to see if the tips are dirty.. If they look ok then leave it
As I said I'm pretty sure they are only there to comply with EURO 4 emissions laws.
Ps I'm only a 3rd year apprentice mechanic so I may be wrong
Post your avg speed when posting your fuel consumption!
I get average 15L/100km at 30km/h in my sv6 which I know is ####ed
My VZ Wagon Exec does 11.5-12L/100km around 40-45km average speed..
If your gear changes are between 2000-3000rpm you deserve to be using that much fuel. I do a lot of city driving with gear changes between 1500-2000rpm and I'm averaging 12.5km/100 consistantly. My gear changes only go over 2000rpm if I'm in a hurry and if I do that consistantly, my fuel usage climbs noticably.
