Guys hoping someone can help me I've just bought this nudge bar from eBay
And it only came with 4 bolts I think I am missing some other parts have emailed the seller to see if they are still on his car. In case the seller does not have the brackets does anyone recognize the design? And who makes it?
VZ Wagon (dual fuel)
Lowered on lovells springs
VE SSV rims
2 1/2 stainless exhaust with DD exit
Can you take pictures from other angles? I would like to see where it is meant to fix off under the car.
It looks alot like it is missing another bracket. You could get someone to make you up one. If you look at a right angle, you should see some bolt holes. If you weld up something it should fit on nicely. Remember this is just a nudgebar.
The most you can really expect is a nice place to mount up some spotlights.
