Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By heyitsEnricoPallazzo
Thread: rear control arm issue
    sleek_vp is offline sleek_vp
    VP Commodore V6
    Mar 2007
    brisbane
    Default rear control arm issue
    i need to replace the left rear control arm on my vz exec (existing one is dodgy, inner arm is slightly bent left from previous owner accident and is pulling the bush left causing the bush shell to rub the chassis where it pivots and make a constant sqeek noise) and was wondering if anyone has done this before and could tell me the procedure to do this. any help is much appreciated, thanks
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Basically you have to at least lower (if not remove) the entire rear subframe to access the bolts to remove the control arm. Which is a major PITA if you don't have the facilities, time or tools.
    Having done camber bushes I would not do it again.
    Good luck.
    VS Berlina
    Jul 2011
    Victoria- Eastern Suburbs
    the irony. i have just replaced the control arm and swing arm on my rear right hand side of the vz. took me about 4 hours to do it with one other guy, limited equiptment (we basically jacked the rear end off the ground and went from there) and yes its more of a C yoU Next Tuesday job (theres like 5000 effing nuts and bolts haha). but providing there is no structural damage the replacement part should just slot in, bolt up and be ready to roll. but you must have the patience because it will fight you to the end. enjoy
    VS Berlina
    Jul 2011
    and yes you basically have to removed the sub frame to access the bolts.. there is limited space between you spanner and the bolt head though so it is an intricate and frustrating proccess without all the tools
  1. Climate Control Issue
    By Speed16 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-12-2011, 08:50 AM
  2. VX Cruise Control Issue
    By scrano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2011, 07:38 PM
  3. Cruise control issue..
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 09:54 PM
  4. Another VS climate control issue
    By Smallies in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2009, 10:08 AM
  5. Cruise control issue
    By ST4s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2008, 08:08 PM
