hi ive got a vz ss and every time i exit the car with the keys or the keys are still in the ignition, when i shut the doors they lock , i have had to break in now 3 times and am getting sick of it lol does anyone have an answer cheers =)
For starters, never leave your keys in the ignition unless you are in the car!
But otherwise, potentially there is an issue with your BCM. Others with more experience on BCM issues might be able to shed some more light than I can however I suggest checking the charge level of your battery first as poor quality/poor charge batteries can wreak all sorts of havoc in these cars.
-My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
ill charge the battery and see how she goes ..... cheers
ya gotta get into your options menu and change one of the locking options I forget the name. to get into the options menu when you start the car you press either up or down or mode while the computer performs it's system check. you will see it come up on the display on the dash.
I had the same exact problem a month ago left my car running and shut the door and it auto locked and that's how I fixed it.
Thats correct.
My wifes key has the door lock function set and mine doesn't so someimes when I use her key I have almost been caught by the locking doors.
On mine the different keys also have different seat and mirror settings when opening the car.
So go into you options menu and change the door lock function with the key you use in the ignition.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Both of you have the right ideas, but it is not what the OP is/was experiencing. Their doors are locking when closed regardless of whether the key is in the ignition or just sitting on the seat, and since these aren't exactly BMWs that we drive they can't sense that the keys are in the car and not in our pockets (meaning that the doors aren't just locking because the car thinks that you are inside it!).
its caused by a faulty drivers door actuator our vz adventra does it more after its been raining the door handle gets a little stiff to open as well because the actuator is not fully open replace the actuator or see if there is any part of the lock and handle has come loose
but my money is on the actuator
If it is still happening why don't you go and get a plain key cut (without the elctronics) and hide it under the car somewhere.
I did this on my old wagon because you could lock the car with tail gate still open and closed the keys in the car a couple of times so having a key outside definitely helped.
Yes the alarm will sound until you use the electronic button on the proper key.
