Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By FATMOE
  • 1 Post By aaronevolution
Thread: traction control
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Default traction control
    tried searching, but is there a way to disable traction control permanently without having to press the button? i read for a vy you push out one of the clips in the wiring somewhere, but is that the same for a VZ? how do the LPG guys do it on the vz?
    cheers
    Spoken by a true member of The Committee
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by richardpalinkas View Post
    cheers
    I read that too, can't remember where but yes fairly sure the procedure is the same for VZ.
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    04 VZ SV6 A5
    Feb 2010
    the collective time you spend bastardising the current switch with this 'mod' would essentially be the time spent pressing it every time you get in your car
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    I asked the same question on the forums long ago no one gave me an answer. I did some research of my own and what I came up with is this.
    Pull out the ABS plug (big one in the engine bay) check to see if you have a PIN 27 on there, if you do push it out with a pin or nail. DONE.
    If you dont have it, supposedly it can be disabled via the ECU. Now I dont entirely beleive this at all.
    The other alternative is to change the ABS module for a none TC one.
    Thats the best I can help with.
    WL CAPRICE
    Mar 2011
    VY Clubsport R8
    Sep 2010
    I suggest you grab a screwdriver and hammer it into the TC button and get a permanent marker and write traction control OFF on you cluster screen. Done
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    I turn it off when I get in all the time other than when it is wet. Then it is pretty much a necessity. I wouldn’t permanently disable it.
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Jun 2011
    Quote Originally Posted by aaronevolution View Post
    Because it's cool to go around corners sideways?
    Its fun but not recommended on public thoroughfares.
    May 2009
    Gold Coast
    thanks for the people who actually tried to answer, but yes, everytime i hop in the car it comes off, regardless of when its wet or dry. personally, id rather be in control of when i lose traction, and for the people that are gonna say why do you need to turn it off, learn to drive and have control of your car, im sure there will be a time when u go sideways and think 'traction control will save me', and something will be screwed with the traction control unit, and u will be screwed.
    and also to note, having traction control turned off in the car does not necesarily disable it, i have at one point gone to the drags, lost traction and had the low traction warning come up, not ideal in that situation to see that message.
    so check the abs plug? will do, see if it makes any diference
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Traction control has saved my car from stepping out in the wet more that once. There was one occasion were it didn't do what it was supposed to do, yet I didn't screw up and came out ok.
    This was the first and only time I have had my car completely side ways!
    You're car is newer than mine, so mine does properly disable traction control when turned off.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VZ SV6
    Dec 2009
    I remember reading somewhere that there is a relay for the t/c? and you pull it out, wrap some electrical tape around the prongs and stick her back in. Something along those lines
  15. #15
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Best RPG ever
LinkBacks (?)
  1. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  2. Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2011, 05:57 AM
  3. VS Traction control ??
    By W8INL9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2010, 10:57 AM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. VT traction control
    By GM 62 in forum Electrical Wiring / Questions
    Last Post: 06-01-2006, 09:39 PM
