Results 1 to 5 of 5
Thread: Check engine light after plug change
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    Default Check engine light after plug change
    i changed the plugs in the usual way, i didnt disconect the battery tho. i did have the key out of the ignition for the netire process. now an orange icon lights my dash. any suggestions as to what i did wrong?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Double check that you've plugged everything back in as it should be.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    make sure they are torqued correctly. Alloytec is a cry baby at times, and chances are you are suffering from it being too tight or loose.
    SBM
    SBM is offline
    VS 5Spd
    Aug 2010
    Streaky Bay
    I did the same on a VE yesterday and founf that the plug right on the back of the manifold was still unplugged. It's pretty hard to see. Even after I plugged it in and started the car the engine light was still on so I had to plug in the scan tool and clear all codes for it to go out.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    or disconnect the battery for half hour, that clears most faults off the screen
    Spoken by a true member of The Committee
  1. engine check light came on then went off??
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2011, 11:02 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. VX SS check engine light
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2010, 05:56 PM
  4. 304 Engine not running after plug change
    By stocky in forum V8 Development and Modification
    Last Post: 14-12-2009, 08:57 AM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
