Results 1 to 2 of 2
Thread: Copy of Original PCM Calibrations
    VZ SS
    Aug 2011
    South East QueenslandV
    Default Copy of Original PCM Calibrations
    Is there a way of getting a copy of a car original calibrations. The car is a VZ SS, and doesnt have the original PCM installed, but a mail order tune that doesnt have the original calibrations for speedo, fuel etc. Can you somehow get Holden to give the info to you?
    WL Caprice
    Mar 2011
    Most of the items should be able to be calibrated in service by a tech. Check the setup mode of the cluster. In the Caprice, you can adjust most (fuel, speedo etc) settings. Might be able to in the SS as well. Involves monitoring the fuel use and also measuring the distance travelled. Haven't bothered to play with it myself, had no need.
  1. VN L3 cluster calibrations
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2010, 01:06 PM
  2. Ve gts copy rims?
    By nicko9990 in forum General
    Last Post: 25-05-2009, 12:50 PM
  3. Just need a copy
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 11:28 AM
  4. Copy Right
    By Garth in forum General
    Last Post: 02-03-2004, 03:57 PM
