Results 1 to 12 of 12
Thread: Please Help Help !!! Car not turning over battery checked all ok .
    vz 2005 commodore
    Aug 2011
    darwin ,nt
    Default Please Help Help !!! Car not turning over battery checked all ok .
    Has any of you commodore owners had the following problem occur to you vz 2005 series 2 with 105k on clock.
    My car was sitting for a few months not used. Recently had a friend go to start it take for a run. Car did not start not turning over nothing! Checked battery all good.
    Had mobile mechanic check advised me could be key reader or computer.
    Advised that the computer was not recognizing the key . Tried all spare keys still same problem.
    Any one out there had this occur with there vz and was the cause as above or diifferent.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Could be your auto trans switch try it in Park & Neutral. Do you get the "OK" in the instrument cluster self test window when you turn ign on?? You may need to get a Tech 2 to re program your keys to the BCM.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Engine should still crank with a dodgy key, but not start.
    Check fuses, relays etc.
    VY SS
    Jun 2006
    Albany
    06 vz sv6
    May 2011
    south east sydney
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Ignition on do the dash lights illuminate?
    Any clicking when you try to crank?
    Headlights on are they bright?
    Silver Certified.
    vz 2005 commodore
    Aug 2011
    darwin ,nt
    Yes alll dashlights and external lights bright and ok .
    does not click when key is turned.
    And battery was checked by mechanic stated all good. Then went into the speil re my first post >
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Just for fun, try re-seating the ECU fuse and see what happens.
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    vz 2005 commodore
    Aug 2011
    darwin ,nt
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    My sister was stuck for 3 hours one night with the same isiue.. It was still in drive...lol.... But yeah, obviously you have checked that?
    vz 2005 commodore
    Aug 2011
    darwin ,nt
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by hewsi2011 View Post
    how did they fix it?
    By putting it in Park or Neutral???!!!
  1. turning over slow, but battery fully charged
    By kinkyaz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2011, 07:29 AM
  2. Replies: 0
    Last Post: 14-09-2010, 12:25 PM
  3. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  4. Not turning over properly - battery connection?
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2008, 11:22 AM
  5. getting gas tank checked
    By TRICKEDUP in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-03-2008, 08:29 AM
