Just put new sparkplugs in my vz and now it wont start, it tries to kick over and it sometimes sounds like it's about to start but won't. We have triple checked everything Evan put the old plugs back in, no chnagr. Anyone got any ideas?
-Smit
Make sure they are torqued correctly. If not disconnect the battery for a few minutes then try again.
Make sure you've connected the stepper motor connection on the back of the manifold and the one on the TB. Also make sure the Vac hose is back on the booster
Originally Posted by Reaper:
Originally Posted by Jecs:
Does it really matter about torqueibg the Plugs?
-Smit
Is it the Alloytec?
Did you disconnect the battery before changing plugs? If you have you will have to give it some throttle to start it because you may have reset your ECU.
Take the plugs out one by one and crank the motor, watch if the plugs are sparking. Either find a way to stop fuel injection or remember that there is a very volatile fuel mix coming out of the plug hole.
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
still no good guys must be a reason?
-Smit
Do you get the OK on the cluster before startup?
Aerostart into the induction system.
No ok on the cluster, tried aerostart
-Smit
Is the pressure sensor on the back of the plenum (Alloytec) connected?
MAF sensor, TB motor?
