Results 1 to 5 of 5
Thread: VZ Tacho signal wire
    VZ Maloo. 6 Speed. OTR. Tune. Some other bitz
    Jul 2010
    Default VZ Tacho signal wire
    Hi guys, I have a VZ SS Ls1, i know this question has probably been asked before however i cant seem to find it anywhere but iv put a speco rpm gauge in my car, iv wired the pos and neg but cannot find the signal wire anywhere, the only sort of answer i could find is to wire it to the "purple" wire on the number 1 coil. or rip out the cluster and wire it in however i dont wish to pull it out. can anyone confirm this purple wire? or if there is a wire in the engine bay to link to. ( i know vx ss had the packs behind the firewall and it was a brown white? wire which was easy enough... but VZ SS dont have that)
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Pin 30 (brown/red) on the cluster plug should be the signal wire for the cluster tacho. Disconnect to be sure.
    Jul 2010
    VZ A4 Saloon
    Nov 2010
    Jul 2010
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    First remove the cluster bezel (two screws).
    Click image for larger version.
    You are a absolute Champ mate!!! Works a charm!!! thanks so much!!!!
  1. tacho signal wire
    By Clint_G in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:04 PM
  2. Where is the Tacho Signal Wire
    By bobby_wayne in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2011, 06:45 AM
  3. amp signal wire ???
    By lodgie in forum Car Audio
    Last Post: 28-02-2010, 04:27 PM
  4. tacho question (signal wire???)
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 11:00 PM
  5. no signal for tacho
    By tweakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2007, 03:09 AM
