Results 1 to 2 of 2
Thread: How to change bearing on front wheel
    VS Berlina
    Jul 2011
    Victoria- Eastern Suburbs
    Default How to change bearing on front wheel
    Hi guys i havent found a "how to" in this particular case, i (yes i admit i like to go fast) had a little accident in my 04 VZ SV6. apparantly its a common occurance i bent the rear control arm but replaced that and screwed by wheel alignment at the front now there i have a slight void, nothing too serious and so far i have fixed nearly everything to a total of just over $300..so much cheaper than paying someone else. now the final step to repairs is replacing the wheel bearing in the front right hand wheel. i bought one from a wholesaler (about $160) and id prefer to do it myself if possible to save on the labor costs any help/advice would be awesome.
    How to change bearing on front wheel-bearing.jpgHow to change bearing on front wheel-bearing-2.jpg
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    First question - did you ensure the hub you bought has provision for ABS?
    Assuming you have the correct hub, this is the process. Pardon the steps which seem obvious but safety is essential.
    1. Jack up front of car and place on stands - don't just leave it on the jack.
    2. Remove wheel.
    3. Remove top caliper retaining bolt from slider pin, push top of caliper forward and remove pads.
    4. Slide caliper off lower mounting and hang caliper from front spring with a piece of wire.
    5. Unbolt caliper bracket (2 bolts) NOTE Some guys leave the caliper attached and just remove the caliper and bracket together. It's your choice.
    6. Remove disc. It could be seized on the hub - usually are - so spray hub with penetrating oil and tap disc off lightly from behind, rotating the disc to ensure it comes away squarely.
    7. Disconnect ABS connection from back of hub,
    8. Remove three bolts holding on the hub using a 10mm allen key. They will be very tight as they have Locktite applied when new.
    Installation is a reverse of this process.
  1. possible front wheel bearing failure
    By vz_sv6_owner1990 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2011, 04:59 PM
  2. Front Wheel Bearing Hub Assembly
    By Logzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2011, 07:11 PM
  3. Front wheel bearing assembley
    By HeRoNz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2010, 10:14 PM
  4. How to change a front shocker bearing?
    By richardbignutsonstato in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2009, 11:56 AM
  5. vt ss front wheel bearing noise
    By rox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 03:07 PM
