Results 1 to 7 of 7
Thread: Vibration coming from front right wheel?
    VS Berlina
    Jul 2011
    Victoria- Eastern Suburbs
    Default Vibration coming from front right wheel?
    About 2 weeks ago i hit a gutter side on and both rims on the right hand side buckled only slightly. The rear control arm etc were warped as f*k but i have since replaced the entire thing, new disk, pads etc. Now there is no structural damage (thank christ) or diff damage but i believe the front bearing may be f'd. i can still drive the car, (took it for an alignment before i realised the vibration) but there is still a vibration which increases upwards of 80km so i have not been driving it in fear of further damage. what should i do ;?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Wheel out of balance? Buckled rim?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VS Berlina
    Jul 2011
    rim is buckled, 0took it to get machined and replaced it with the stocky, luckily it hasnt caused anything serious. im confused though because if it was bearing damage the guys who did the alignment would have noticed right?
    Hangman's Avatar
    Jan 2010
    Not necessarily. So the vibration is with the stock rim?
    VY SS
    May 2011
    Auckland
    Jack the car up and try to turn the wheel (in direction of camber). Movement in this direction is often the wheel bearing.
    Check for play in all the bushes and ball joints as I would think this is more likely the issue.
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    you also may need to check the tie-rod ends. This will give you vibration through your steering at the 80kpm speed you are talking about.
    VZ executive
    Feb 2009
    warragul
    Sounds like a buckled rim I have the same problem once I hit about 100 the car gets a Nasty vibration I've seen the warp too when I had the wheel balance not a pretty sight lol
  1. clunk coming from front right wheel when turning
    By brisbane_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2012, 07:57 PM
  2. Idle vibration, missing lower front grill, wheel squeaks and other little niggles
    By keith.s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-07-2011, 02:33 AM
  3. Front Wheel Vibration
    By dah_man_ben in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-12-2009, 11:52 AM
  4. Vibration in front wheel
    By lemonaed in forum General
    Last Post: 02-12-2008, 09:34 PM
  5. Intermittent vibration - Front left wheel
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 02:51 PM
