so driving home last night, at a set of lights and just out of the blue, she just died!...towed it back home and looking at it this morning, fuel pump is fine, (also has a full tank of fuel)...it cranks over and starts, idles like a pig for about 3 seconds and then dies...any previous experiences or ideas? I know i most likely need a diagnotics test done but any help would be appreciated....damn cars! haha
Check the coil packs. Sounds like one has shat itself
you say it has a full tank..as in you just filled up??? bad fuel maybe...
Ok here's a few things.
1. How long ago was its major service? (all fluids, plugs, leads, etc)
2. How many km's has it done?
3. What petrol station did you fill up at and does it have a high turn over?
4. Before the aforementioned incident did it have any more problems?
2 speed powerglide...fast and faster
Fuel filter? Sucking in air due to a leak?
If you're basing the full tank on the gauge, I had a VX that showed 1/4 tank when it was empty. Stuck a few liters in off it went. I'm totally suspicious of the gauges.
It's not much use asking a question like that here, all you get is ideas, truth is there are way too many things that could cause that problem. Take it to your mechanic.
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
hey guys cheers for the feedback, its only done 90,000kms, ive only had it for 3 weeks so i still have a stat warranty so it went on the back of a tow truck back to the dealership and its their problem now! haha
lol at some of the responses in this thread!
Silver Certified.
