Results 1 to 7 of 7
Thread: 2006 ss thunder ute overheating
    vz ss thunder ute
    Aug 2011
    gold coast
    Default 2006 ss thunder ute overheating
    Hey,
    Have owned my ute for over 4 years now and havent had an issue with overheating untill recently. have done just under 90,000k's and recently finding my car overheating first thing when start for the day. Checked all the basics (radiator fluid, engine oil, fans start correctly) everything is fine. dropped it off to a machanic who couldnt fault it. didnt over heat for a week following this but has started again and the engine temp warning came on now and just trying to work out if it would be the thermostat or water pump (maybe the impellar). does it take much to check/pull out the thermostat to confirm if it is kicking in or maybe getting stuck.
    has anyone else had similar issues?
    The coolant hasnt been flushed since i have had it, would this change anything.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Change thermostat, an go from there.
    It's the cheapest thing to do yourself.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    ^^^ that one. Had a sticky thermostat on my last SSV. Swapped it and everything was roses. Sold the car shortly there after for the E3 just in case
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Almost definitely a thermostat. A mate told me that the thermostat is in a stupid place where you have to remove the gearbox to access. Is that right? Sounds odd even for Holden.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    vz ss thunder ute
    Aug 2011
    gold coast
    Issue has now been resolved, it was due to a faulty temperature sensor. I couldnt have been sure it was a thermostat also but FYI.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by CRUSTIN View Post
    V6 is on back of engine and a complete ****, V8s are on the front and easy.
    Silver Certified.
  1. 2006 VZ SS Thunder 6.0ltr
    By ZOMBIE in forum VY - VZ - WK - WL - V2
    Last Post: 14-09-2011, 08:39 AM
  2. My VZ 6L Thunder
    By MISS THUNDER in forum VY - VZ - WK - WL - V2
    Last Post: 31-07-2011, 10:49 AM
  3. Replies: 1
    Last Post: 13-06-2011, 02:38 PM
  4. My Thunder ute
    By Thunder chris in forum VE - WM
    Last Post: 02-06-2011, 04:49 PM
  5. What is the difference between a Thunder and a Thunder Upgrade
    By vtcommodo3800 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-07-2009, 04:48 PM
