Results 1 to 4 of 4
Thread: Parker lights
    VZ Berlina
    Aug 2011
    endeavour hills
    Default Parker lights
    i have a VZ berlina, does anyone know how i can access the parker lights? I removed the black protective casing that hides the dust filter and whatever else. The battery is in the way and the radiator fluid are also blocking access to the parkers, do i have to remove all these items? I'm not too sure about removing these things, help is appreciated.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    you could start by reading the forum names, because you've posted in a sponsors forum about audio and lighting modifications
    Its listed in your owners manual.
    Failing that, you do have to remove some stuff to get into it.
    VZ SV6
    Nov 2009
    just move the battery aside
    you can take the coolant resovoir out. Just twist and lift
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Its semi hidden. My advice is to move the battery and the coolant reservoir as Edz just said. And use your hands to feel around. I tried to look in there to see what I was doing and found it just made things more complicated then they needed to be.
    Parkers are the easiest of all the bulbs to change so dont worry about it being hard.
  1. Parker Lights
    By Nic92 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-06-2011, 08:15 PM
  2. Parker Lights
    By vrgurl87 in forum Electrical Wiring / Questions
    Last Post: 03-07-2009, 09:10 PM
  3. Parker lights.
    By randomhero365 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2009, 09:21 PM
  4. parker lights
    By bpottz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2008, 09:10 PM
  5. Parker lights
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2005, 09:47 PM
