Results 1 to 6 of 6
Thread: GEN 3 radiator
    VZ commodore
    Apr 2011
    perth
    Question GEN 3 radiator
    hi all
    just wondering is a LS1 radiator will fit into my vz v6?
    and if so do you reckon it will do anything in performance wise
    thanks
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    He may be asking a serious question you know. To answer your question. Yes it should fit, you need to remember that Holden is very smart and lazy at the same time, they mass produce the cars and leave the engine fitting as an afterthought. Meaning you can easily put an LS series engine into a car that came factory with the Alloytec.
    So yes, the LS radiator should fit into the engine bay of the V6 car, some slight modification may be required, namely around the hose area.
    As for performance, I cant say with a 100% certainty but I would say it would give no performance gain, youd be lucky to see a difference in the temperature it runs at.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by azazeldeath View Post
    He may be asking a serious question you know..
    Quote Originally Posted by blakeoner View Post
    hi all
    thanks
    so so serious...its a radiator
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    wont do jack, the standard radiator does its job at keeping the engine at optimum temperature. having the engine at normal operating temperature is where the power is, not whether the engine is cold or not
    Spoken by a true member of The Committee
    VZ commodore
    Apr 2011
    perth
    ok thanks
  1. Rb25/30 Radiator hose for vl radiator.
    By vl_2010 in forum Straight 6 Development And Modification
    Last Post: 23-06-2011, 11:46 PM
  2. should external trans radiator be inline with radiator compartment
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 10:50 AM
  3. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
