Hey guys just a quick question what would be the price to get a key cut for my ss and were to go ........... Cheers!!!
Mr Minit does them, I bought mine from Holden, ended up getting a Chev key as it was $10 cheaper ($55 from memory)
cheers man
If your key just has a flat battery have you tried replacing the battery? You can buy the correct battery from Jay Car Electronics. You can also get aftermarket shells with new rubber buttons off e-bay if that's waht's busted on yours
Any locksmith can do them, don't go to holden as they will overcharge you for it.
Holden just end up taking the keys to their local locksmith anyway and charge ontop of what the locksmiths charge initially. Skip the middleman!
Is that the same for all vz keys? I forked out $160 for my key(from holden).
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
Do a google search.
Holmart and others stock. All you need to do is get it programmed.
alright i look into it thanks guys
