Results 1 to 6 of 6
Thread: VZ Timing Chains
    VZ Ute
    Aug 2011
    Central Coast
    Default VZ Timing Chains
    Hi All i,m a newbie and i have just fitted a new set of cam chains to my VZ Ute and im having a problem when i start it it runs like its 5 cylinders and once warmed up it runs fine but shut it off when hot hot and restart it it runs like crap again and it is also throwing up the code for bank 1 cam sensor over advanced i was thinking this could be a vacumm leak on the lower intake gasket as holden gave me every other gasket but this one .
    Any help on this would be fantastic
    Thanks In Advance Justin
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Now when you say you fitted the cam chains, does that mean you personally did it. Or did you pay some mechanic to do it? If its the later I would get the mechanic to have a look at it.
    If you did it, I would have to ask, how experienced are you at mechanics?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The error code is the hint. Sounds like you have the wrong timming mark on the new chains. I'd be taking the timming cover off to check it all again or getting a mechanic to look at it ASAP. Out of balance motors can go bang (seen it with my dads Sigma and a wrong timming mark)
    Picking up bit's of alloytech motor off the road may not be much fun when you go to find a replacement motor.
    and 3 Dangerous non ABS VN's
    VZ Ute
    Aug 2011
    Central Coast
    The timing marks are spot on and yes i did it myself i have the full instructions and timing mark diagram to do the job and i think im pretty handy with a spanner it only throws the error code up when its dead cold you clear it and its all good have taken it up the freeway and it has heaps of power and runs fine it just runs bad when first started i have orderd a new intake gasket set today so hopefully its a vacumm problem.
    VZ Ute
    Aug 2011
    Central Coast
    Im a mechanic by trade but i have been out of for the last 6 years i have the instruction and diagram of how to do this job and everything lined up with the diagram it seems like a vac leak cause once it gets going and warms up it runs great its just on strart up it runs like a dog hot or cold
    VZ Ute
    Aug 2011
    Central Coast
    Well fitted new gaskets today but still no good worked out that its only running on 3 cylinders on cold start up but when warm its running on 6 the whole right hand bank is dead on cold so looks like i have to open it up again and have a look i have done a compression test and all cylinders have the same compression could this be a cam angle sensor Playing up or a timing issues its doing my head in
  1. Alloytec Timing Chains replacement
    By Chaney in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-06-2012, 05:41 PM
  2. VZ Timing Chains - hard to replace?
    By dharry in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-04-2011, 06:12 PM
  3. timing chains
    By Calais_5sp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2007, 06:47 PM
  4. Snow Chains on VZ Ute
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-08-2006, 08:44 PM
  5. Snow Chains
    By BottFodder in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-01-2006, 09:23 PM
