Results 1 to 14 of 14
Thread: Hu fascia
    07 VE
    Dec 2008
    SA
    Default Hu fascia
    Hey guys just picked up a pioneer single din hu and the single din fascia kit for the vz. Headunit doesnt seem to fit in the fascia seems to be about 5mm to wide for the gap any one else have this problem. Am i missing something really simple? Cheers guys
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Have you taken the metal casing off with the stock headunit. It has a big screw at the back of it. Chances are thatll fix your problem.
    If you need me to I can see if I have mine laying around in the shed.
    07 VE
    Dec 2008
    SA
    Oct 2010
    Darwin, NT
    Ah right, try load it in from the front then, I am assuming its the face area of the head unit that is being a pain (mine did the same I just mounted it forward more and never had a problem still looks clean).
    07 VE
    Dec 2008
    SA
    07 VE
    Dec 2008
    SA
    Oct 2010
    Darwin, NT
    wow ok maybe take the face off the headunit, push it in from the back (to avoid the width) and put the face back on, failing that perhaps file down one side of it and just screw it off on one side (also what I had to do with mine).
    VR Calais
    Mar 2011
    Plumpton
    Pretty sure the deck goes in from behind and screws in on the sides
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    07 VE
    Dec 2008
    SA
    Glad im not the only one thats had the problem. Il keep trying tomoro cheers for the responses lads
    07 VE
    Dec 2008
    SA
    Just managed to get it in very very tight fit. Cheers for help. In the end it did go in from the back.
    2005 Adventra LX6, HG monaro
    Sep 2010
    Perth Australia
    Hi Matt,
    I have the 7250sd deck and the same looking facia, my metal cradle that came with the deck slid straight in form the front and the deck inside that, It looks like there may be prob with the black plastic bit you baught. If you are not happy with the looks i would suggest taking it back.
    07 VE
    Dec 2008
    SA
    Yeah cheers mate i got the hu in but cant get the hu frame/trim piece that goes around it on might have to see if there are other opotions
    Sep 2010
    Perth Australia
    facia trim clips onto the metal cage that goes around the radio, mine was tight to get the cage in, slightly bent when installed, then squeezed the deck into the cage.
    07 VE
    Dec 2008
    SA
    Ah il have a shot at it again might not have the cage pushed in far enough. Cheers
  1. is a vt das fascia the same as vu/vx??
    By JUDDO13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2011, 08:48 AM
  2. Custom Fascia
    By wickann15 in forum General
    Last Post: 10-08-2010, 09:49 PM
  3. Stereo Fascia???
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2009, 01:17 AM
  4. vt/vx fascia fit?
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2009, 11:53 AM
  5. Double Din Fascia
    By Vee Tee in forum Car Audio
    Last Post: 16-05-2008, 10:56 PM
