Results 1 to 7 of 7
Thread: Engine will not start Next Moring
    VZ
    Sep 2011
    Speers Point
    Default Engine will not start Next Moring
    Hello can anyone help me on this one, I have a VZ 2005 Commodore, 70,000 Klms. If I start the car reverse it out of the garage, wash it and then restart engine move back to garage, the next morning the engine will not start, when starter motor is engaged it tuns the motor over very quickly as it their is little or no compression. Last time two days ago I had to wind it over for a very long period, it eventually started, garage was filled with smoke and unburnt gases. If I had of driven it around the block this scenerio would not have occurred. Any clues would be appreciated. Thanks Garry
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    Common problem with some cars. If the engine has only been run for a short time (e.g moving the car in/out of a garage) the engine gets "flooded" with excess fuel (Hence the smoke and gasses when it finally kicks over.) Therefore it chokes when you start it up next.
    If you come across this again, put your foot on the accelerator while the engine turns over, the extra bit of throttle helps it to burn/get rid of the excess fuel.
    To prevent this, drive the car around the block as you've described, or just let it idle for a few minutes before switching it off.
    Need a part number? PM me.
    Luke.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    Quote Originally Posted by Luke52 View Post
    wont do anything on the alloytec... no throttle cable
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Quote Originally Posted by impulsesv6 View Post
    Yeah but I recall reading in these forums that it activates a purge function ... so it achieves the same thing in the end.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    On most modern fuel injected cars if you give it full throttle on cranking the ECU reads this as you wanting to clear a flooded engine and cuts fuel completely.
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    FBW acts the same as cable when ignition is on.
    Silver Certified.
    Sep 2010
    Mulgrave, VIC.
    Hmm, didn't think of that. All I know is that I did it on mine when I encountered this issue, and it worked.
    Luke.
  1. VN Will Not Start After Washing Engine
    By joe seinfeld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2010, 02:49 PM
  2. VT - Exchange engine won't start
    By Phoon270 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2010, 08:18 PM
  3. What the **** was that... engine start up issue
    By dirtjumper005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2009, 09:31 PM
  4. SV6 Engine Characteristics on start up.
    By Co_cker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-03-2007, 10:49 PM
  5. VS engine fanruns and no start
    By Jason in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 07:18 PM
