Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By the_great_white_2000
Thread: Replacing Ignition Coils
    '06 VZ Commodore T190 Alloytec
    Sep 2011
    Default Replacing Ignition Coils
    Hey guys, I have a VZ T190 thats missing whenever I go over 3000rpm (‘Check Powertrain’ alert follows, scanner does not pick up any error codes). It was determined that one or more of my ignition coils are stuffed. Mechanics quoted me over $800 to replace all 6 with labour. Stuff that...
    I acquired 5 good ones off another VZ and want to put them in myself. How do I do this, do they just plug in, is there any procedure I need to follow? Just want to double check before I attempt anything. Thanks.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Sep 2011
    Quote Originally Posted by Torquative View Post
    this might help
    VZ alloytec (how do i change spark plugs)
    I just did a search for change VZ coil, hope that helps!
    Thanks, that helps. Cheers.
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Purely plug in, I think there may be 1 bolt at the end of the lead if I remember correctly.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    $800 isn't really that bad for a supply and fit of coils. The coils retail for $100 each...
    Need a part number? PM me.
    Luke.
    Torquative's Avatar
    Jun 2005
    yeh its pretty straight forward once you get into them, one bolt that holds them on and they just slide out and slide in.
    Just getting into them thats tricky!
  1. Ignition coils...
    By JBDrifter in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-10-2011, 10:34 PM
  2. Thermal Grease on Ignition Module and coils?
    By b3h3m07h in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-06-2011, 04:00 AM
  3. MSD Ignition Coils and Leads
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2009, 09:48 PM
  4. Ignition Coils/Module
    By don0xer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 08:38 PM
  5. Dfi Module, Ignition Coils
    By Gav95VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2004, 11:02 AM
