Can anyone tell me where i can get a 12v pic up in the boot easy. There is a wired looking plug in the roof of my boot right in the middle where a hole is. I thought i could use it thinking it was a plug that the clubsports use for there 12v output in the boot but couldn't get power out of it. also in the fuse panel it say boot input so i put a fuse in it but still Couldn't get power out of it. Any help would be good help
Check out My VZ SS 6.0l NOW CAMMED http://forums.justcommodores.com.au/...new-vz-ss.html
try behind the right hand side rear quarter carpet, near the plug that you have to pull out to pull back the carpet, there is a connector with 2 wires and one of them is the supply for the factory sunroof when fitted, then all you need is a fuse under the dash.
I pulled it back and found a heap of wires coming out of the lights into a trailer plug. Would it work if i hooked the leds im puttin in the car into the park lights on the trailer plug so the leds only come on when i turn the lights on???
