Results 1 to 14 of 14
Like Tree3Likes
  • 2 Post By HoZy
  • 1 Post By Sabbath'
Thread: Diff Upgrade - Warning
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Default Diff Upgrade - Warning
    I have a 2006 VZ Executive - mods galore.
    I post this as just a warning to those thinking of 'beefing up launch power' off the lights....... by changing their differential.
    I went from a 3.08 NON-LSD to a 3.45 LSD. Now after approx a year of having it....... having the car tuned etc. I had a really odd cyclic knocking sound, started off light, got louder over months mostly at light throttle, off throttle and highway........... which eventually turned to a loud sound and highway vibration.
    Turns out, my drivers side (used to be the non pickup wheel due to no LSD)........ broken half shaft, damaged main drive half shaft. Easy to fix........
    My point is....... better diff = more pressure placed on the half shafts which are probably not designed for the higher ratio. So if u do your diff, get aftermarket stronger half shafts. Torque launching at lights also obviously doesn't help them last......... not that I do hardly ever but still.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by bigdaddycool View Post
    Quoted for the LoL's...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Yeah...i dont really get what you're trying to say?
    I run standard half shafts im my car with over 230rwkw and never had an issue with them. Just as there are plenty of people running much higher numbers through standard items.
    Yours were just old and shit.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    Rofl vz manga torque launching at lights
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    What are these "mods galore"? MAFless tune, pod, body kit and as much mang as the main street can handle?
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    wouldnt the lsd diff actually mean less stress on the half shafts as the power will be divided equally between 2, rather than the full power exherted into just the one?
    Spoken by a true member of The Committee
    SV6 P-Plater's Avatar
    SV6 P-Plater is offline Dont Speed In Surbubia
    VZ SV6
    Feb 2011
    VS Stato l67
    Mar 2009
    Melb
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Just in, the mod list.
    K@N pod filter (+50kw)
    Rear muffler cut out (+50kw)
    Three bottles of octane booster (+25kw per bottle)
    Chopped springs (Outhandles supercars)
    Hiclone (acts like turbo +200kw)
    Engine covers removed (+50kw)
    Thats 425kw over standard, no wonder the diff broke.
    Silver Certified.
    Sep 2008
    It would seem given the part numbers they may put a weaker half shaft on cars that come stock non lsd.... as they don't need to be strong.
    I'd say half my issue is the ability to jump from anywhere to 6000rpm at will in the appropriate gear ..... which i'll detune somewhat.
    Sep 2008
    You are running a VX yeh? maybe your was stock supercharged or is an 8? ..... perhaps it was designed with lsd originally?..... As for 230kw, engine or wheels?
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Read what he posted mate, he said 230RWKW (Rear Wheel Kilowatts).
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VZ SS 6.0L
    Aug 2011
    I have seen a absoloutely smashed (twisted cv joint) half shaft on a brand spankers VY or VZ HSV (it`s been a while now and god only knows how that happened ). This is only the second time iv`e known of one to fail. But there is probably more out there that have failed. Generally you will find they are extremly strong enough for most road cars.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    this is how to break a cv...
    closing in on 600hp with nos and hoosier slicks
  1. Replies: 21
    Last Post: 25-08-2010, 08:39 PM
  2. SV6 Diff Upgrade - 3.45s
    By mattsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-11-2009, 06:53 PM
  3. VB-VC Diff upgrade options help.
    By Flange in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2009, 11:54 PM
  4. V8 Gearbox & IRS Diff upgrade
    By broderikb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 12:11 AM
  5. Upgrade VT diff
    By SS202 in forum General Discussion
    Last Post: 19-12-2006, 12:36 PM
