Results 1 to 10 of 10
Thread: VZ Commodore Doesnt Start [Video]
    VZ Executive V6 3.6L
    Aug 2011
    Default VZ Commodore Doesnt Start [Video]
    Well this problem as happend in the past very rarely so i didn't pay much attention to it.
    But recently the car wont turn on every now and then, I jst put it though a service and the computer comes up with service soon. The only way to turn the car on is to switch off the ignition, lock the doors then unlock them then turn it back on, and also comes up with random error messages every now and then.
    Taken it to some mechanics for couple of days and they couldnt diagnose the problem.
    I'm thinking theres something wrong with the starter motor and then the security system kicks in and wont let it turn on.
    Video below:
    http://www.youtube.com/watch?v=I9P8BvCQxhM
    04 VZ SV6 A5
    Feb 2010
    maybe the immoboliser isnt making contact on the key? mechanics is your best bet so they can scan it
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    looks alot like its the immoboliser as Slipper said.
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    had this prob before... make surte it has more then 30 L of fuel in it, remove your fuel pump fuse, turn the ignition, reinstall it, try and start untill the fuel is picked up
    Life starts at 200km/h
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by impulsive View Post
    Whats that meant to do?
    Silver Certified.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    bottom of ignition barrel .......
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    Looks like an ignition problem as it didn't disable when you unlocked the car the first time... the security warning light was flashing the first time which basically gives it away. Best bet is to see an Auto electrician i'd say.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Make sure the ring around the key barrel isnt getting stuck in, it should spring out to make contact with the key.
    Silver Certified.
    2005 LTZ
    Jun 2009
    To me it seems that either your starter motor or the Flywheel has got some problem.I have 2005 Lumina LTZ,When i try to start the engine,it gives me some "tak ,Tak,tak" sounds from downside engine and it does not crank at all.I brought a mechanic,he opened starter motor,rotated flywheel by his hands and then put back the starter motor.The car is perfeclty starting back normally.But mechanic said to be that flywheel has to be replaced since some of its sharp Edges(i dont know what to call them technically) are broken and when engine is stopping in a position where they have to meet starter motor, then engine is not cranking again.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    use a small screw driver to bend the metal tabs out on the ignition barrel... also use a lil silvo and clean the contacts on the key and barrell
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. VZ cranks but doesnt start
    By anarklov3r in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-07-2011, 03:32 PM
  2. doesnt start
    By MatthewP in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2011, 03:21 PM
  3. vt v6 cranks but doesnt start
    By MY 5.0L VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 11:37 PM
  4. VS sometimes doesnt start in 'P'
    By SV62NV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 07:18 PM
  5. Car Doesnt Start In Park
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2006, 04:34 PM
