Results 1 to 5 of 5
Thread: ABS Fault VZ V6
    2005 VZ Executive 3.6lt V6
    Apr 2011
    Altona North
    Default ABS Fault VZ V6
    I have an ABS Fault coming up on the Dash, and it won't allow the car to start. I have checked the ABS fuseable link and also disconnected the battery and re-connected after 5 minutes with no success.
    Also occasionally the SRS Airbag warning light comes on.
    Has anyone seen this before ?
    Any thoughts would be helpful.
    Thanks
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Once but I hope it isn't for the same reason, when my LSD got replaced I stupidly went to a mechanic, turns out they didn't put the passenger side bearings in right, the ABS module managed to hit the housing a few times and break. It then made the entire wheel wobble once my computer noticed all that happening it wouldn't start again.
    It took the mechanics ages to get it to start even with a tech-2 (I am happy about that, they screwed me around alot I am glad their job wasn't easy).
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    05 VZ SV6
    Jul 2011
    Central Coast, NSW
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    abs fault usually comes up when the battery is near dead. happened to me, replaced battery and havent seen it come back
    Spoken by a true member of The Committee
    VZ SV6
    Mar 2011
    Bunbury
    Charge your battery mine did it aswel and layer on it came up with more faults. Charged the battery and was all good
  1. Engine fault light comes on and stays on but fault code says no fault?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 05:46 PM
  2. 'ABS Fault'
    By System in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-07-2010, 07:44 PM
  3. ABS Fault
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 09:46 AM
  4. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
