Results 1 to 9 of 9
Thread: vz tranny problems.. help!!
    vz v8 wanna be
    Sep 2010
    caloundra
    Default vz tranny problems.. help!!
    g'day guys,
    yas driving along today and noticed my tranny (assuming) knocking in final gear at around 80 -90, bout 1600 rev.
    does not do it any other time,
    any ideas?
    cheers.
    VZ Lumina 4sp
    May 2011
    Can ya describe the knocking sound better?
    cheers
    Quote Originally Posted by Ryley View Post
    Hahaha, all you need now is a unit sticker; extra 600HP.
    SS Catback
    MACE Cold Air Intake and Insulators
    147rwkw
    vz v8 wanna be
    Sep 2010
    caloundra
    more of a metal clunking noise? i can hold it at around 80km/h and accelerate lightly and it will do it,
    only does it if im doing this eg, does not do it under medium to hevey acceleration if this makes sense?
    cheers
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Could be a driveshaft CV which only plays up at certain RPM/Load
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    WL Caprice
    Mar 2011
    Engine mount moving? I knew a bloke with an SS that did similar things - replaced the engine mounts and it was cured.
    vz v8 wanna be
    Sep 2010
    caloundra
    thnks for the replys guys,
    is there any way to test if the above suggestions are in fact the issue?
    cheers
    vz v8 wanna be
    Sep 2010
    caloundra
    ok so heres the weird thing, knocking seems to "come and go" so to speak,
    one day it will do it and the next day it wont?
    so thinking it might be a misfire??? remember only happens at 1600 rpm, under light accel???
    coil? fuel? tranny?
    dont have the coin to take it in so any help would help
    cheers.
    vz v8 wanna be
    Sep 2010
    caloundra
    coil? fuel? tranny?
    cheers.
    03 VY ss hothouse green
    Jun 2011
    hobart
    i tend to agree with CapriciousWL it does sound like a broken engine mount have you noticed if it dose it once when under heavy acceleration then jump off the gas?
    put it in gear and load it up and see if you can see the engine lift.
    if it was a miss-fire you would notice it more under hard acceleration also you would notice a drop in power and power delivery wouldn't feel as smooth.
    if it was the cog box you would expect to see diffferent symptoms.
    and bad fuel/fuel pump (not sure wich one you where talkin about)... just geting it to start can be a battle.
  1. Anyone have problems with tranny on their HSV E1 ?
    By omarko in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-07-2010, 07:41 PM
  2. tranny problems
    By vr1962 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2009, 08:31 PM
  3. I think i have tranny problems......
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2009, 07:36 PM
  4. Tranny Problems
    By Lupetto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 02:37 PM
  5. 92 vp tranny and spedo problems
    By cavantrev in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 10:01 AM
