Results 1 to 4 of 4
Thread: VZ SS 40K SERVICE - 5 years old - what needs to be replaced??? Oman =50 deg days
    VZ SS Nov 2005 5.7 stock (Middle East Spec) LHD
    Sep 2011
    Muscat - Oman
    Smile VZ SS 40K SERVICE - 5 years old - what needs to be replaced??? Oman =50 deg days
    I have recently purchased a low KM VZ SS here with a good service history.
    As the car is now 5+ years old - I am looking to ensure reliability.... its bloody hot here in Muscat (50 deg days are common for 3+ months each year)
    Should I be changing the radiator hoses and belt?
    Does the Auto transmission need to be flushed
    What is the type of coolant that should be installed ?
    below is a list I found on a holden serevice centre site ( i have mixed the 40k service with the 60 month / 120k service)
     Inspect CV Joint Boots for Damage
     Inspect Vacuum Hoses & Connections
     Lube All Locks and Hinges
     Inspect Battery (Levels/Security/Clean Terminals)
     Inspect/Adjust Drive Belts
     Inspect Cooling System (Levels/Hoses/Leaks)
     Inspect/Top Up all Fluid Levels
     Inspect/ Top Up Trans. & Diff (Levels/Leaks)
     Inspect Underbody (Security/Leaks)
     Inspect Exhaust
     Inspect Steering/Suspension/Engine Mounts
     Inspect Brake Pads & Discs Front & Rear
     Inspect Power Steering Hoses (Leaks/Condition)
     Inspect CV's & Drive Shafts (Joints/Boots/Leaks/Damage)
     Reset Service Lights
     Replace Air Filter
     Flush Coolant - 6 Litres – Glycol
     Change Brake & Clutch Fluid
     Change Engine Oil & Filter
     Replace Fuel Filter
     Replace Wiper Blades
    Parts
    Oil Filter - 1 unit(s)
    Air Filter - 1 unit(s)
    Fuel Filter - 1 unit(s)
    Engine Oil -- Refer Specs. - 6.2 unit(s)
    Flush Brake Fluid Material - 1 unit(s)
    Glycol Coolant - 6 unit(s)
    Wiper Blades
    Your expert advice is appreciated...
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    just use the 40k service as a guide
    if your brake fluid hasn't been changed it would be worth it especially in Oman, definitely do the coolant preferably red GMH (holden) coolant
    the trans won't need flushing unless oil is really dark (highly doubt it) - just get a new filter and 4L gearbox oil
    VZ Lumina 4sp
    May 2011
    Id be checking pads and rotors too
    Quote Originally Posted by Ryley View Post
    Hahaha, all you need now is a unit sticker; extra 600HP.
    SS Catback
    MACE Cold Air Intake and Insulators
    147rwkw
    A slow1
    Nov 2005
    yep service as 40k pages says
LinkBacks (?)
  1. 01-10-2011, 05:49 PM
  1. Can you reset the service reminder before due service interval?
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-07-2010, 12:20 AM
  2. SV6 service vehicle soon 8000Ks after service/repairs
    By Cyaegha in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2008, 10:33 PM
  3. good days and average days
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2007, 09:59 PM
  4. any bad days?
    By Sabby in forum The Pub
    Last Post: 26-01-2007, 06:03 AM
