Results 1 to 4 of 4
Thread: Mcai
    VZ executive
    Sep 2011
    Default Mcai
    so what is the actual difference between a vz exec airbox and monaro airbox? do u need to do the two hole mod to get the extra induction?
    or will the mcai be enough of a difference?
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    The MCAI will work just as well the 2 hole mod.
    The Monaro airbox just has a 'scoop' at the front. Which just does the exact same job as the 2 hole mod. The Monaro airbox just looks neater (only if you are lazy otherwise it still looks good).
    Personally I suggest going with the 2 hole mod, or even having a look at MACE's website for their cold air intakes.
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    Ive done the 2 hole mod with the MCAI
    The Monaro shroud is like azazeldeath said, just a scoop that attaches to the front of the air box. It would just replace the 90 degree pvc fitting with minor cuts to the shroud to fit.
    To answer your question you need the 2nd hole for the extra induction.
    The Monaro shroud will catch a little more cold air from behind the headlight, not much more than the 90 degree bend.
    Another half hour is all you need to cut out thr other hole and its done.
    Brendan
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    I did post pictures of how I did the two hole mod on my CV8 which showed the Monaro scoop but it got deleted for some reason.
  1. [VZ] Two Hole Mod and MCAI
    By BullittSV6 in forum Holden Commodore How-To's
    Last Post: 03-03-2012, 11:19 AM
  2. mcai
    By kngsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2012, 06:53 PM
  3. Help with mcai mod
    By wadevzss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2009, 09:51 AM
  4. MCAI on VT Ecotec 3.8L
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2008, 07:38 PM
  5. mcai or otr cai
    By corza3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2008, 09:49 PM
