Results 1 to 4 of 4
Thread: VZ Binnacle Gauges
    VZ SS
    Jan 2011
    Default VZ Binnacle Gauges
    I want to fit the binnacle gauges to my VZ SS 2006 6.0litre with climate control , Could anyone help me with a few things about them? I need to know what kit to buy E.G. vy clubsport vz clubsport vz monaro Ect? Also Is there a plug behind the climate control and where could i buy these?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Phantom vz sv6
    Sep 2011
    Vz's with climate control use the double hump binnacle from the vz r8, while vz's without climate use the vy style single hump. Wiring for the voltage is relatively easy for both, there is one standard wiring harness for both. the climate should have a plug behind or around the climate control unit, while non climate has it at the bottom right hand side hidden where the flip down holder is infront of the gear stick, both will have plugs already on which should have yellow, black and red leads coming in. Yellow for power (positive) black negative and red for switched power from the headlights for the gauge lighting. They cables are in parallel at the top to be connected to each gauge individually.
    V'z have a different oil pressure sender and accompanying harness one for v6 or v8, which I suggest getting someone qualified to do as it must be one correctly to be sure no oil seeps past.
    Hsv_direct from eBay should be able to help with everything you will need, good guy and great help.
    VZ SS
    Jan 2011
    Is there any i can buy that don't need to be cut up to fit the storage compartment??
  1. SV6 Binnacle Gauges
    By CKaras in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-09-2010, 05:01 PM
  2. BINNACLE GAUGES into 2006 sv6 ute
    By matt2386 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-05-2010, 03:55 PM
  3. Vz dash kit-binnacle,loom,gauges
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-05-2009, 04:41 PM
  4. Alternate gauges in binnacle
    By DavoTheGreat in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-03-2006, 08:30 AM
  5. VZ Black Binnacle Gauges
    By ScottB_33 in forum Parts And Other Items For Sale
    Last Post: 12-02-2006, 07:58 PM
