Results 1 to 7 of 7
Thread: Largest tyres without modification?
    05 VZ Executive
    Aug 2011
    Default Largest tyres without modification?
    Just wondering what the largest tyre is that would be able to be fitted without any modifications?
    Currently have 17s on and there is a lot of room from the tyre to the wheel hub.
    Cheers.
    VZ Lumina 4sp
    May 2011
    Pop some 19"s and lower it a tad, looks tough imo
    Quote Originally Posted by Ryley View Post
    Hahaha, all you need now is a unit sticker; extra 600HP.
    SS Catback
    MACE Cold Air Intake and Insulators
    147rwkw
    VZ SV6 AND VL CALAIS TURBO
    Jan 2010
    brisbane
    I got some 19's g.max eagles 245/35/r19 with superlows they fit
    MR HAVICK
    VS Berlina
    Mar 2011
    Woodford QLD
    How large a tyre you could fit would be seriously affected by the offset of the wheel too. The same tyre on one wheel will not even fit on the car because of lack of clearance, yet be just fine on a different wheel.
    You need to look at wheels and tyres as a whole, not two parts.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    As has been said, depends also on the rim you fit it on. I'd imagine you could fit a 275/30 with the correct size / offset wheel. With a light guard roll and a reasonable height. If it was crazy low then things would change, similarly if the suspension was very tall.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    With VE offset rims I just fit 245/35/19s with SSLs and unrolled guards.
    Silver Certified.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I have superlows with 245/30/20 unrolled, they just fit. But only because the rear suspension is independent.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  1. What's the largest / Most you have moved in a VZ?
    By Holden=#1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-08-2010, 03:49 AM
  2. Worlds largest speeding fine.
    By Ado in forum The Pub
    Last Post: 14-08-2010, 11:57 AM
  3. largest front rotors you can fit to a VT?
    By ryanlok15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 07:22 PM
  4. Worlds largest tape ball
    By Troy711 in forum The Pub
    Last Post: 09-04-2010, 04:28 PM
  5. largest tyre size on vr ute
    By boonga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 02:23 PM
