Results 1 to 6 of 6
Thread: DIFF change over?
    VZ SV6 2004 190kw
    Apr 2011
    Maffra
    Default DIFF change over?
    Hi,
    Just bought a VX LSD 3.46 Diff and want to change it over myself from my stock VZ SV6 2.86? diff (if thats the ratio it came out with)
    Just wondering what it take to change it over.
    Its just the centre peice (Gears inside + housing.) if anyone could give me some pointers as to how to do this, that would be great.
    Cheers.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    , yep reasonably easy , however there are 2 top bolts hard to get at , you have to drop the entire rear suspension cradle down enough to get a spanner on them , they are bloody tight , you will need a breaker bar. your current diff will be a 3.07, but check the sticker on the drivers side of your diff , you might already have a 3,46 in it , but it may not be a LSD.
    vs exec
    Jun 2008
    Pretty easy to do mate. Just unbolt everything, swap it over and bolt it all back in. Just make sure you don't miss anything when doing it back up. And may as well change the diff oil while your there.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by colgf View Post
    There are 4 bolts on the top. 17mm
    And if you undo the rear mount, you will have enough room. Unbolting the swaybar makes it even easier.
    EDIT: The rear axles are an 8mm Allen Key
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VZ SV6 2004 190kw
    Apr 2011
    Maffra
    cheers for all your help guys, i'm thinking about doing it this sunday, so i obvously need to jack the car up (don't have a proper 4 poster or antything) so then i chcok the wheels and then i put in nutral and then take hand break off so the diff will drop and then after that i'll undo those 4 bolts on the top of the diff and then what? haha i wanna give it a good crack, i do need to put oil in it so i'll be doing that, but what about where the axels meet? do i need to undo them some how? cheers.
    EDIT: i just read the 8mm allen key haha, how many screws are there?? and is that all that i need to undo?
    cheers.
    VS Stato l67
    Mar 2009
    Melb
    6 allen key screws on each CV joint to drop the axles from memory.
  1. diff change
    By neilsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-09-2010, 01:00 AM
  2. change diff oil vz sv6
    By jjbird85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-08-2010, 03:07 PM
  3. Diff Change
    By Chirpstr in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-01-2008, 08:01 AM
  4. Diff oil change?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 03:26 PM
  5. diff oil change
    By oliver in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2006, 03:10 PM
