Results 1 to 12 of 12
Thread: part numbers
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default part numbers for SS fog lights
    anyone got part numbers and prices for SS driving lights, including brackets, screws and dash switch?
    and for SS side indicator vents and everything included to install them?
    aaaaaand.... with the side vents, what is involved in installing them? can a panel beater just cut the holes with a nibbler and not have to repaint the whole gaurd?
    Aug 2005
    [QUOTE=Troy711]anyone got part numbers and prices for SS driving lights, including brackets, screws and dash switch?
    QUOTE]
    Ive seen a few pairs of fog lights and switchs for sale on ebay a few times.
    And theres always at least one pair of vents for sale on ebay also.
    Sorry, unsure on part numbers.
    Aug 2005
    Just did a search on ''vz'' on ebay. Theres about 447325364326532 pairs of vents on there. Found 3 pairs of fog lights by searching "vy" They should fit vz?
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    *super bump*
    ok, forgive the somewhat smart arse reply but can someone reply to this who CAN ACTUALLY HELP instead of telling me to look on ebay? i appreciate the 'help' of those who have tried but it didnt help me at all. i know someone on here has posted the part numbers for the lights (with prices), i just cant find it after looking for an hour.
    thanks for your help... unless you tell me to look on ebay..
    VZ Storm ute M6
    Dec 2005
    Northern Sydney
    Sorry to hi-jack your post.
    Ive got factory fog lights on my VZ Storm but they are not the ones stamped "SS".
    If you want them for extra forward lighting they do bugger all. They light up "just" in front of the car and also slightly out to the sides. Apparently some of the major brands (Narva?) have decent driving lights thats give extra forward distance and fit in the same holes.
    Are you a member of any other commorode forums ?
    I dont have DEFINATE answers for you, but the following may help ? (ive stolen the info from another forum)
    Parts Required to fit VZ SS Guard Vents.
    92159962 Fender RH VZ SS RRP $253.00
    92159961 Fender LH VZ SS RRP $253.00
    92148171 Vent Asm RH VZ SS RRP $71.50
    92148172 Vent Asm LH VZ SS RRP $71.50
    92175663 Lamp Ind Asm RH VZ SS RRP $27.50
    92175662 Lamp Ind Asm LH VZ SS RRP $27.50
    http://www.nvu.com.au/products_singl...ge=3&section=1
    Fitting Fog Lights to VY accliam:
    S1 Calais light switch with foglight function - $41 (p/n 92113753, beware SS switch is different as its black seemingly and a bit dearer)
    And relay - $5 (p/n 92109510),
    You can get the SS front bar from holden for about $325, however it is un-painted..... you'll have to pay extra for the paint which your dealer should organise with a paint & panel place that they deal with.
    The driving lights are about $230 for the 2, but you will then need to purchase a new headlight switch (dial which pulls out to activate the foggies) and then get an auto electrician to wire them up for you.
    All up, you'll need:
    Part # Part Description Price
    92083826 Front Bumper Bar $326.70
    92108180 Holden Badge Grill $57.17
    92076499 Fog Lights (2) $232.32
    92113753 Headlight/Fog Lights Switch $41.14
    ....plus any screws, nuts, etc that hold everything together.
    Aug 2005
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by kmbattle
    Have u checked ebay?
    yea a few times
    i got a quote for 127 EACH for the lights. f.uck that. ill keep checking ebay and maybe try NVU
    2004 Pontiac GTO 5.7/M6
    Dec 2005
    North Carolina, USA
    This may seem odd you, but I am in the US and have a GTO and just purchased the SS side vents and lights. I am planning on installing them on my car, and also was curious as to what goes into the install. I would think just a good body shop could take care of it.
    For parts, I bought from Hunter Holden (http://www.hunterholden.com.au/) The parts mgr is Sean Beatty--great guy!
    Anyway, I'm sure he could help you with anything you need.
    If you do find out what it takes for the install, please let me know. Right now, I'm trying to figure out why the 3 pieces that make up the vents are melted together at the clips...makes disassembly for painting damn near impossible!
    Anyone with info, please post up!
    Thanks.
    2004 GTO PBM M6
    Mods Installed:
    PM-FL Stage III Heads--12:1 CR, EDC Cam, JBA's, ASP pulley, Custom exhaust w/Thermal Res. Tips, B&M Shifter, AMW Catch-Can, TB Bypass, AZA Z-1's w/Toyo T1-S, 20% Tint, Mobil 1, RP Trans & Diff, NGK TR6...and more
    http://www.ls1gto.com/forums/attachm...1&d=1130877409
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    id suggest buying new front quarter panels with the holes precut. try www.nvu.com.au cos i think they sell then to suit monaro
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    vt ss 5.0l 5spd
    Apr 2005
    Dec 2005
    North Carolina, USA
    Thanks ozzy dude!!!
    I'm still not sure if I'm going to cut a hole in mine or just buy the fenders...the shipping is the killer when buying parts from 'down under'.
    Quote Originally Posted by Troy711
    http://www.nvu.com.au/products_singl...ge=1&section=1
    link for the yanky dude with the GTO
    2004 GTO PBM M6
    Mods Installed:
  1. Hsv Part numbers
    By MarzVP in forum General
    Last Post: 29-11-2009, 09:13 PM
  2. vb-vk part numbers
    By Dilweed in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-08-2008, 05:39 PM
  3. part numbers
    By adamandtanya in forum General
    Last Post: 14-02-2008, 02:14 PM
  4. need part numbers
    By cb1177 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2006, 12:25 PM
  5. Part Numbers
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-07-2005, 09:46 PM
