is it easy to put in new unit,i mean is the wireing the same does it just plug straight in or do u have to do some ajustmants, im only talking bout the head unit tho not speakers,
na its not that difficult and you can get the connector loom for the headunit from supercheap or repco for a specific headunit for vz, so u dont need to chop any wires just plug and play
kool thanks for ya help
just make sure you get the specific commodore adaptor, not just the generic ISO plug adaptor, Holden in all of there wizdom switched 2 pins around from the world wide standard - the +12v wire and ignition feed have been switched, if you desk loses it's stations and settings when the ignition is off you will need to swap these wires around.
