Hi guys my vz sv6 power steering not working on idle or when I come to a stop but works fine when driving or engine revs are up any ideas will help thank Steve and I have bleed it and still the same
MR HAVICK
Are u sure the steering isn't just light when driving and it doesnt wrk at all
No you can put in neutral rev to 1000rpm and it works perfect just and idle or turn at lights it gets heavy have to turn it with two hands
MR HAVICK
I bet your p/s pump is giving up. Get your p/s pressures checked at a workshop, that will tell you whats going on.
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
