Results 1 to 9 of 9
Thread: vz help
    vt
    Oct 2011
    wa
    Default vz help
    hi all
    noticed today that if i put my foot down to overtake the car feels like its miss firing any ideas
    ie plugs, coil pack, ???????
    any help would be great
    cheers carl
    VZ SENATOR
    Mar 2009
    Hey mate,
    Yep you are on the money, a misfire is usually going to be either your plugs or coil packs. How many ks has your car done. Is it a v6 or v8? Have your plugs been replaced?
    vt
    Oct 2011
    wa
    Quote Originally Posted by mattsv6 View Post
    Hey mate,
    hi thanks for your reply
    car is a standard v6 exec with 119000ks and i dont think the plugs have been replaced but we are the second owners of the car
    VX acclaim S2
    Oct 2009
    Why would you ask a question you know the answer to? A misfire has got to do with ignition, so why not go spend 25$ on plugs an see if that fixes it? If that doesn't, check for a difference in resistance in the leads. If that doesn't eliminate it u can start looking at coil pack
    vt
    Oct 2011
    wa
    Quote Originally Posted by kizza50 View Post
    sorry to ask for others advice but i thought a forum was based on sharing with others your knowledge and advice
    the reason for my question is that it only happens when i put the foot down
    it seems fine at idle this is why im a bit unsure
    VX acclaim S2
    Oct 2009
    Again..... U stated as ur knowledge misfires are from ignition related such as plugs, it's not un common for a spark plug to seem fine at idle but under load failing due to a weak electrode
    VZ SENATOR
    Mar 2009
    Quote Originally Posted by carl1965 View Post
    I had the exact same issue mate, the misfire would only happen on about 70% or more throttle. I replaced the spark plugs but the problem ended up being the coils. I bought a new set from ebay and replaced them myself which solved the problem. I would say start with new plugs and go from there...
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    Alloytecs have no leads mate. Best to change plugs to start off with then see how it goes, if that doesn't fix it it'll definately be one of your coil packs. A scan will give you an idea of which one is buggered.
    VX acclaim S2
    Oct 2009
    Quote Originally Posted by VZCALAIS190 View Post
    That's correct I thought we were talking about eco's for some reason
