Results 1 to 5 of 5
Thread: ABS Failure ???
    VZ Executive
    Jun 2009
    Default ABS Failure ???
    Hi, I wonder if anyone could give me some ideas about my cars ABS failure problem?
    The brake pads are new (6 months ago) and I checked all the wheels, nothing wrong with the pads, speed sensors-wiring seems fine. The brake booster seems OK and I cannot find anything wrong with the master cilinder (brakes well).
    On start up the ABS failure comes on (not every start-up), during driving it comes on and goes off now and then. But when I brake (not every time) I hear a grainy noise at the front wheels and can feel a"boing" on the brake pedal.
    It feels like metal on metal, but the brake pads have easily 90% pad left.
    Does any one had this problem before? Any ideas? Can only get it to Holden next week.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    could be a few things and stupidly as I found out Holden use that warning for many brake issues.
    Mine have been related to the handbrake and low brake fluid in the reservoir when Ive had the ABS failure show up on start up, but it sounds like you have more to it then that.
    VZ Executive
    Jun 2009
    Thanks Torquative,
    I think it is more than that, yes the brake fluid is full, and I have adjusted the handbrake.
    I would like to know the what the symptoms are with a wheel sensor faulure. I have read that it may case a grinding sound at the wheel and a pedal "boing".
    from this site Brake & Hydraulic Problems
    Torquative's Avatar
    Jun 2005
    Mmm - could be, and if its giving out false readings its trying to apply ABS to that wheel
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    I get ABS fail messages on start-up for a second or two whenever the battery is a little low. Don't know why it does it there's definately nothing wrong with the ABS. Apparantley it's normal so i just ignore it now.
LinkBacks (?)
  1. 09-01-2012, 02:24 PM
  1. BCM failure
    By Calaber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2012, 06:22 PM
  2. VZ key failure
    By Juan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2012, 03:22 PM
  3. VS BCM Failure..
    By db_sampson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 04:54 PM
  4. ESC Failure
    By VicCop in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-02-2010, 12:56 AM
  5. Failure
    By Ms Stato in forum Jokes/Humour
    Last Post: 12-11-2005, 09:09 AM
Tags for this Thread
