Results 1 to 11 of 11
Thread: will a shift kit fix it??
    vz Executive
    Aug 2011
    BF BEND
    Default will a shift kit fix it??
    when needing to give the vz 4speed auto a kick down to 3rd to execute afast passing manouver, eg, b doubles roadtrains, plently in this part of the country, the trans does not engage immediatley and the motor revs out, the car has allways done this since ibought it at 32k, has now done 56k and the trans was recently serviced, my queary is would a stage 1 shift kit remedy this, thanks for any advice.
    what we have here,is a failure too communicate!!
    VL Calais
    Sep 2011
    mechanics love kids who put these shift kits into their cars thinking ur geting the 1/4mile faster, its just tighter gearing up thats all, if anything it reduces speed
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by Macka123 View Post
    I have no idea what you are trying to say, but what??
    A shift kit, your basic one, provides you with some different valves and some mods to the valve body to increase the fluid pressure, which in turn makes the bands grip harder/faster on the drums, thereby reducing the time to engage the next gear and also reducing the heat caused by the slipping of the bands.
    Ronald Reagan (1986)
    vx
    Aug 2011
    sa
    or get them next time too adjust your line pressure, accumalator i think its called, as stated above less wear on trans,,,,but im confushed if your car is revving out then its already in third, you can move the lever too third before you over take, hence bringing the car up on the revs, plant your foot and over take,, or it could be slipping clutches/bands, but find a great transmission guy too look at it,,, a common thing i see out on the open country roads people are scared to put their foot down when overtaking trucks, most modern cars like to revved a bit,
    vz Executive
    Aug 2011
    BF BEND
    loopie, what i'm saying is i would like 3rd to engage in a quicker and more positive way when ineed to plant the peddle, the trans does not slip, just slow to hook up
    VS Stato l67
    Mar 2009
    Melb
    So quicker, firmer shifts reduce speed now do they? I just keep learning new things on this forum
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by ivabiggen View Post
    well don't wait for the 'kick down' manually shift it in to 3
    vz Executive
    Aug 2011
    BF BEND
    Quote Originally Posted by Munz View Post
    i was under the belief [perhaps mistaken] that this could damage the trans.
    vx
    Aug 2011
    sa
    the biggest killer in any 4/5 speed auto is too leave in there,, around town third is great, adjusting line pressure is thru all gears,,,, the biggest downfull is youve gotta get use to it when your stationary and you put it into any gear it engages quickly/thumps,, but that means less wear on your clutch pack, dont be afraid to let the car drive around a bit in second with rev reson too make the motor work a bit,,,
    VX Berlina
    Apr 2007
    Nope, it perfectly fine. No damage will ensue as long as your sensible about it, like no selecting 1st at 60km/h continuously, and stuff like that.
    vz Executive
    Aug 2011
    BF BEND
    the trans in my vz is the police style where you don't have to deress button, i've never used this function cos have been unsure of it's exact reason and afear of damaging the trans.
  1. HELP: Column shift to floor shift conversion?
    By FULLY 17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2012, 03:37 PM
  2. VT LS1 shift point calibration and shift kit question
    By Spyda in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2011, 03:51 AM
  3. Performance Shift Module VS stage 2 shift kit
    By justbad4you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 01:19 AM
  4. shift kit and shift module?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 09:18 PM
  5. wat dus a shift kit do
    By pro1438 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2006, 04:44 PM
