Results 1 to 4 of 4
Thread: doreHolden VZ replacement motor
    VZ Executive
    Oct 2011
    Kensington WA
    Default doreHolden VZ replacement motor
    Hi all. Ihave to replace the engine in my VZ Commodore. I've been given different advice concering the 10 HBA numbers. Must the whole number match or is it only the first 4 digits after the 10 HBA? Any help would be appreciated.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Might be worth ringing Holden about that one. Not many blokes here have had engine swaps, and even less would have had your problem.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    2005 VZ Storm S Ute
    Apr 2011
    Orange
    i dunno how much help i am mate but i am in the process of replacing the engine in my vz ute, its the 3.6 alloytech. all ive managed to find out is that if your replacing your engine you have to get the exact matching one as for some stupid reason they arent interchangable, for mine i spent ages tracking down a 10hbb, most i could was a 10hba or 10hbl, also if you look under the bonnet at the front passenger side of the engine bay there is a silve tag with diffeent serial numbers embedded in it, the bottom code is your engine type and you need to match that aswell, i think mine said leo on it
    05 6sp VZ SV6
    Aug 2006
    Singleton NSW
    I was recently looking into changing my engine also, i was told from holden that the numbers have to match up otherwise it will have problems with the computer. Apparently they had to sort through 19 different engine codes. All i know for sure is i wouldnt be going out and buying the first alloytec i find. Talk to Holden
  1. VZ Motor Replacement
    By madbart2000 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-09-2010, 04:11 PM
  2. replacement motor VS
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2009, 08:29 PM
  3. wiper motor replacement
    By half-fix in forum General
    Last Post: 12-01-2009, 11:00 PM
  4. replacement motor for vt
    By peter white in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2008, 06:45 PM
  5. Starter Motor Replacement...
    By anastaisija in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 04:27 PM
