Results 1 to 4 of 4
Thread: Vz noisy fuel pump ?
    Vz sv6
    Oct 2011
    Default Vz noisy fuel pump ?
    Anyone had any problems with fuel pumps or the annoying whining sound they tend to make when there in need of replacement on any of the vz versions ? I know my old vl had a noisy fuel pump and I remember the sound which my vz sv6 is slightly starting to make , not sure if it's on it's way out or just a common problem ..
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I haven't heard of it as a common problem, but there has been threads on this before. Its worth doing a search because its more helpful seeing what ended up happening rather than suggestions.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    Vz sv6
    Oct 2011
    Iv searched but can't find anything , I was gonna get a new fuel pump and change it anyway as they aint that expensive but I think it's more of a job for a workshop than a home garage job ... It's weird though coz it only does it every now and then and car seems to misfire every now and then too but I'm guessing thats becoz I havnt changed all my coil packs yet which r all breaking down .... B4 I changed the first coil pack the car felt like it was surging and even with one coil pack replaced car seems good but still not as gutsy as it was so that's y I'm thinking something to do with fuel pump
    VZ S 175 Ute
    Nov 2010
    Have your fuel pump pressure tested. That may tell you something.
  1. Noisy Power Steering Pump
    By 1TUFVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2011, 04:16 PM
  2. Noisy Fuel Pump... Ideas?
    By Mick1988 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2010, 12:03 AM
  3. new pump 044 noisy and right fuel pressure?
    By vlosity in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-08-2009, 06:59 PM
  4. Noisy Fuel pump VN Wagon
    By Disperse_daredevil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 06:03 PM
  5. noisy fuel pump
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-08-2005, 07:10 PM
