Results 1 to 2 of 2
Thread: check power train and reduce performance warning
    2004 vy calais
    Oct 2011
    Default check power train and reduce performance warning
    Just repaired my wagon after damaging the front so all radiator condenser air filter radiator support etc replaces and now the acceleration seems faulty and it says check power train and reduce performance any ideas with what's wrong??
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Have a look for any damage yourself, if you can't find anything you might need to take it to get the codes checked. Just to check codes its $55at Holden, some small shops are $40, ultratune I heard was $80-100.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  1. safety mood active + power reduce + check engine
    By AHMADMAIK in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-07-2011, 11:45 AM
  2. Sv6 Check power train.
    By wassaby in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-07-2010, 05:57 PM
  3. Check Power Train Warning
    By dave1979m in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-12-2009, 07:23 PM
  4. Check Power Train ?
    By trademark in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 09:14 PM
  5. Check Power Train ?
    Last Post: 16-11-2005, 10:49 AM
