As the tittle suggests i want to take off the rear parcel tray does anyone know how to do it without breaking it?
Remove the rear seat then you will see clips along the top that were behind the seat back.
Also have to remove the child seat anchors.
Pretty sure I got mine out without removing the side trims but could be mistaken.
Silver Certified.
Pretty sure there's a screw behind the side trims. They're pretty easy though.
Take out seat base, then seat backs, then side trims. Then undo all the clips and bolt under seat anchor.
Bit of a pig, you need to unbolt the middle seat belt while holding the parcel tray up
thanks guys
