Results 1 to 6 of 6
Thread: squeaky fan belt, or water pump?
    05 vz acclaim
    Jul 2011
    Default squeaky fan belt, or water pump?
    so the other day the seal went on my vacum heater control valve and i lost a fair bit of coolant. had to drive the car about 10 minutes with very little coolant :S. now the fan belt is really squeaky? a fait bit of coolant did get splashed on the belts and the tensioner, but im also wandering if i couldhave burnt out my water pump due to the small amount of coolant?
    VZ Wagon
    Jun 2011
    Brisbane North
    Spray a little Silicone Spray or WD40 or similar on the belt while it is turning, a little not a lot, and if the squeak stops straight away then it was the belt.
    If not, remove the belt and spin each item(water pump,idler pully etc) by hand and see if anything is tight or noisy.
    '04 VZ Executive, '98 EL Falcon, '96 NF Fairlane
    Jul 2008
    Blue Mountains, Sydney, NSW, Australia
    yeah use some silicone lube. it will stop it. in my case my water pump leaks coolant onto my drive belt and i have to lube it up every couple of weeks. (only a minor weap not necessarily leak)
    [Linkin Park] Concerts:
    [20.10.2007, Sydney Entertainment Center, Sydney NSW] [11.12.2011, Acer Arena, Homebush Bay, NSW] [15.12.2011, Acer Arena, Homebush Bay, NSW]
    Vehicles:
    [2004 VZ Holden Commodore Executive V6] [1998 EL Ford Falcon GLI Manual Inline 6] [1995 NF Ford Fairlane Ghia Inline 6]
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Quote Originally Posted by [Linkin Park
    :2030138]yeah use some silicone lube. it will stop it. in my case my water pump leaks coolant onto my drive belt and i have to lube it up every couple of weeks. (only a minor weap not necessarily leak)
    Is it a weep around the bearing?
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Is everybody else missing the point where he said he drove an alloy blocked engine with little coolant in it for 10 minutes?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Sabbath' View Post
    Not missing the point at all. If an Alloytec loses the coolant, then a protection mode kicks in (sequentually shuts down cylinder firing to assist in cooling) to prevent major engine damage, whilst allowing the vehicle to be driven (within limits) to safety.
    I've personally had it happen once on an isolated country backroad, when the gasket on my water pump blew out. Lost heaps of coolant and apart from the instrument cluster warning going spastic & the transmission going into overheat mode (locked up the torque converter the whole time & the vehicle feeling like driving with a manual transmission), it allowed me to drive it about 20km or so, so I could get to somewhere I could change out the water pump.
    This happened about 11 months ago & my motor is still going like clockwork.
  1. water leaking from around the water pump
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2011, 08:48 PM
  2. Timing Belt/Water Pump Cost/Place?
    By wol_low in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 12:52 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Squeaky serpentine belt
    By Greg_Sian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-06-2006, 09:34 AM
