Results 1 to 3 of 3
Thread: VZ ute, different computer chip?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default VZ ute, different computer chip?
    Does anyone know for sure if the VZ one tonner Alloytec (05 model) has a different chip in the ECU, due to requirements for carrying heavy loads?
    If so, would it be possible to change the chip to that of a sedan? Thanks.
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    I doubt it would, at most the Ute and Sedan BCM may be different but thats about it.
    Most of the difference is in the gearbox, diff and the actual tray.
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Quote Originally Posted by VYMAD:2029138
    The 1 tonner has a different torque curve, you get the full 320nm at 2400rpm instead of 2800rpm. Same power at the same revs but you get your torque in a more load friendly zone. I assume that would all be done by the chip, but your best option if you want the best of both would be to get a dyno tune. But otherwise I would rather low down torque than what the sedan has.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  1. VZ Computer Chip
    By Crabito in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2011, 11:10 PM
  2. vn/vp/vr computer cop chip
    By jonko in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2010, 12:55 PM
  3. 'chip' in the Computer
    By snowybill in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2009, 03:29 PM
  4. vr computer chip
    By genIIIbandit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2006, 05:50 PM
  5. computer chip
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2005, 01:49 AM
