I seem to this is linked to the air con .... I was driving today and I had the aircon on and i noticed it seemed to be reeving diffidently sort of sounded like air was coming through the car when left the door open a tiny bit but it was not the case so then i turned radio down and it was still there so then i turned air con off it seems o go away every time i seem to accelerate it revs harder or something weird and only does this when the air con is it so i turned air con off and it seemed to go away and drove a bit longer put air con back on and it came back.... any ideas...
Common thing with the vz, air con whines, although mine doesn't do it
Please punctuate your post, it's very difficult to understand.Originally Posted by drelix:2032803
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
Thermo fans will kick in when aircon is turned on...
Silver Certified.
As Ricey said. Plus the engine will rev differently because the a/c compressor needs to be driven when a/c is switched on, adding that bit of extra load.
Need a part number? PM me.
Luke.
