Results 1 to 7 of 7
Thread: Strange accelerator feeling
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Default Strange accelerator feeling
    Hey guys just wondering if its common in a vz to feel a 'grinding' feeling coming from the accelerator at all times, it comes up when i rest my foot on it and also when accelerating, its kind of like a pulse off and on. Dunno how long its been going on for but it seems odd, anyone else felt this ? Just thought id put it out there...
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Phantom vz sv6
    Sep 2011
    At 70kmh I get a small vibration/ shudder back through the accelerator when cruising, I feel it's maybe that gear ratio and that speed resonates? It's not at any other speed
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by RTHL55 View Post
    Does it happen between 75km/h & 85km/h?
    It's your torque converter locking up.
    However it shouldn't make the shudder noise.
    When explaining it to a transmission mechanic use the term flat spot and they will know its the torque converter.
    Do you have a stock exhaust or aftermarket?
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I don't see how all this is possible, its a throttle potentiometer, so it has no direct connection to the engine.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    Jan 2009
    It happens at all speeds, low i feel it mainly, and a little at top end... Welcome to take my car for a spin and see for urself... I do have an aftermarket exhaust but only just got that, and its been it happening way before that... Torque converter - how can u be sure its that ? Is there anything i can DIY to check ?
    VZ S 175 Ute
    Nov 2010
    I'd be changing the throttle potentiometer, I didn't think it would have the capability to put force back on the pedal, but I'm often surprised.
    And it's definately only on the accelerator pedal, There isn't the same pulse on the other pedals? Might also be worth checking where the throttle sensor is mounted to, if the mount is rubbing on something or moving that might do it.
  1. Jerking Feeling
    By grosshom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2012, 11:39 AM
  2. feeling ripped off!!!
    By vt98amazon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2010, 11:12 PM
  3. Oh What A Feeling
    By Dayvo in forum Jokes/Humour
    Last Post: 15-01-2009, 03:12 PM
  4. grinding feeling
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2008, 08:28 PM
  5. Feeling Festive....
    By Lish in forum Jokes/Humour
    Last Post: 20-12-2005, 03:56 PM
