Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: VZ Missfire - intemediate
    Mar 2008
    Default VZ Missfire - intemediate
    I get a missfire (shakes the entire car) but what is weird is it comes and goes at odd times. It started last week at idle then when I thorttled up to 60kmh it stopped or atleast I couldnt feel it, then after that it didnt come back for another week.
    This week same thing happened at idle sitting at the lights, reved up and it didnt come back for the entire drive.
    Now it is happening every second day, something is slowy failing.
    With my vs this happened i just replcaed the sparks and leads but these new vz's coil packs, sparks taking off the manifold to get to them seams like a mission.
    If its a coilpack is there an easy way to tell which one it is? Im guessing i just pull the plug on each while the missfire is present at idle.
    Is there anything else that could possibly be the cause other than coilpacks and plugs?
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    As you said its a good idea to isolate which cylinder it is, when it starts missing pull the leads to the coils 1 by 1, when you find one with no appreciable difference, that's your culprit.
    Then depending if money is worth more than time, change your spark plug on the suspect cylinder. Still happening, change your coil. The only thing I can think of that could cause a miss after that would be an injector. Very frustrating to take the fuel rail off the injectors as the o-rings don't want to move, I know cause I did all my coils and injectors on Friday.
    I've read in some threads that you can test coils with a multimeter, that will need some research.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    Mar 2008
    Replaced all the sparks and coils, still misfiring.
    Next is the injector cleaning but Im not very confident.
    VZ S 175 Ute
    Nov 2010
    I bought injectors for $220 on eBay. Might be easier to do that. Also guarantees that the injectors arnt the issue. After that its worth taking it to a shop, at least they won't stuff around with the parts you already changed.
    Mar 2008
    I noticed a tear in the rubber connector (underneath, it was hiding from me) on the throttlebody - shown in this picture, could this be causing it?
    Attached Thumbnails Attached Thumbnails VZ Missfire - intemediate-capture.png
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by elshonno View Post
    That's your purge hose, not as cheap as they look. Lol about $75 from Holden for just the hose.
    Try and seal up the leak on the hose by using some duct tape or electric tape to see if the issue goes.
    If it does then u can replace the hose or just keep the blk duct tape on.
    This hose shouldn't have an adverse affect like the ones mentioned in the first post but see how you go.
    Where the coils you bought brand new or used?
    Should cost you $550+ for a brand new set.
    Also,
    What plugs are you using in there.
    U should have the NGK PLATINUM LTR6AP-11 of the top of my head.
    Dave.
    Mar 2008
    Quote Originally Posted by CAPRILICIOUS WL View Post
    Also,
    Dave.
    Hey Dave,
    I have the same plugs you mentioned, I also picked up the coils for $60 from repco they are the fuelwiser brands.
    I put some tape over it but your right it didnt have much affect.
    This misfire is starting to give me the shi!ts, today it wasnt happening for the first 20 minutes then im sitting at the lights and bang it comes back again, I bet next time I start the car it's gone.
    Im just trying to avoid spending any more $$$ - theres not alot of that around atm.
    WL CAPRICE
    Mar 2011
    Not really sure about those coils???
    Where abouts are u located?
    I have a set of coils you may be able to try out if u like.
    Also not sure if this may have an adverse affect but make sure you have plugged in the vacuum hose on the back of the manifold with the one way valve. (drivers side).
    They can sometimes fall off.
    And make sure that the plug on the back of the manifold is on properly.
    Keep us updated.
    Dave.
    Mar 2008
    Keep us updated.
    Dave.
    just got hold of a scan tool,
    got error codes p0206
    and p0306
    all pointing to the injector on cly 6.
    It did mention something about coil pack circuit 'f' or something but i didnt write the complete message down.
    Booked into the mechanics up the road tomorrow for testing the cables, I will swap over the injector tonight to see if it misfires the cyl i put it into
    Mar 2008
    Wink
    Put in some repco fuel injector cleaner in the tank, went for a good 30 minute drive and the misfire stopped while driving.
    Howz that $11 bottle solved my problem - fingers crossed.
    The misfire was intermittent before so it might come back, if it does I am sure its the fuel injector now so Ill order a set form ebay and replace them.
    vx
    Aug 2011
    sa
    yea that hose end is a bit cracked as in mine too, i just put some silicon over it as a tempory measure, will replace when i change the plugs, as to replace the hose , the manifold as per plug change needs too come off ,, $80 bucks for a piddly two dollar hose,
    Mar 2008
    update
    misfire is happening again.
    What I have done so far
    Error code 0206 & 0306 - Indicates Cyl 6 misfire and injector problem
    New spark plugs
    New coils
    Swapped over fuel injector from Cyl 6 to Cyl5 - Cyl 6 still misfires
    NFI what to try next, I have read some places it could be the ecm - praying to god its not that.
    Has anyone got any ideas of what to try next?
    Can a vacuum leak cause misfire while running or just idle?
    Any help appreciated I am truly stuck up shit creek without a paddle atm.
    VZ Executive
    Oct 2011
    Quote Originally Posted by CRUSTIN View Post
    You would be able to check for an open circuit, short circuit and read the resistance of the coil with a good multi meter or a megga
    Mar 2008
    Faaaaaaaaaaaaaaaaaaaark Holden!
    6 year old car and its the ECU ###ed up bs
    My VS has been put through more shi!t than this and it is still going, must me made in china crap.
  15. #15
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    ECU? Just get an aftermarket one tuned to your car lol. Would be cheaper :P
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  16. #16
    vz v8 wanna be
    Sep 2010
    caloundra
    hmmmm this is bs, this is exactly what is happening to mine, let us no the damage
  17. #17
    Mar 2008
    they tell me it was 300 labour to diagnose the fault which was testing all connections, fuel injectors and wiring. They also had to monitor the sensors on the scan tool to make sure it wasnt a sensor.
    1200 to replace the ECM, apparantly a guy comes to the workshop and calibrates the ecm - Holden dont have to do it like ive read in some other posts around.
    I dont know if this is reasonable price or not I havent really heard from other mechanics what they charge, I guess the hard work was put into diagnosing the problem which is the ####ed part.
    Il let you know what its like when i get the car back tomorrow, if its still there Ill probably run the mecahnic down.
  18. #18
    Mar 2008
    Just got it back - all good now.
    If anyone is wondering about the symptoms, I can say that I noticed for a months at idle there would be a lsight misfire, maybe 1 or 2 bareley noticable other than a little shake of the car. If this starts happening your ECM is on its way out. They are poorly made pices of crap on this model.
    As I said my 95 VS has laster all these years and is still pearlin'
    I feel sorry for any other sucker out there that becomes a victim of Holden's VZ ECM BS.
    I am now one of those suckers!!!
    Thanks for all the suggestions and help.
  19. #19
    VZ S 175 Ute
    Nov 2010
    Quote Originally Posted by elshonno:2039583
    I have the same thing mate, I changed the coils and injectors trying to get rid of the miss.
    So how much was it to fix? Did you replace it or calibrate it? And can it be done at a dyno tune with vcm suite as I am going to get it tuned soon.
  20. #20
    vz v8 wanna be
    Sep 2010
    caloundra
  21. #21
    Mar 2008
    1500 bucks all up. Only a few people have the software to reprogram/calibrate the new ecm. My mechanic called him out - he charged me 900 for the ecm module and 238 for the labour of prgramming it. If you want it retuned youll probably have to spend another 400 getting that done.
    MY car is running nice now after all the shit i did to it, Im waiting to see if there is any fuel consumption imprivement from the new ecm, the car was churning through fuel pretty quickly beofre.
  22. #22
    VZ S 175 Ute
    Nov 2010
    Did you notice any power changes across the range?
  23. #23
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Mine is doing it too... Argh. I dont wanna pay for a new ECM. Mate how many kays did your car have before the replacement?
  24. #24
    vz v8 wanna be
    Sep 2010
    caloundra
    just a quick update,
    ended up biting the lead and took my car to holden,
    turns out all the above symptoms where due to a cracked plug, derrrh ultra tune
    plug was only 5000km old wft
  25. #25
    Mar 2008
    lucky it was only that:-) did they cracked it when putting it in then?
    My car was on 112 k.
    It might not be the ecm there is every chance you can eliminate what it is, here's what I did in order
    Pull each plug from the coilpack one at a time, when you pull the one out with the problem you will notice no difference in idle - all the others will nearly stall the engine.
    Once you find the cyl misfiring you need to swap the coil pack with another cylinder
    If that doesnt work put in a new spark plug
    If that doesn't work swap the fuel injector with another cyl
    If that still ain't working you need to check the plug receives a pulse
    Trace the wiring back to its source and it'll be the ecm
    1200 to replace:-)
  1. vs ss seems to missfire??
    By sik ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2011, 05:25 PM
  2. vy missfire
    By tassiehunter in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-02-2011, 04:00 PM
  3. missfire
    By andy_man343 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2010, 11:50 PM
  4. Vn Missfire
    By jetoblaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2008, 08:24 PM
  5. Vs Missfire
    By Chris Everett in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2004, 05:56 PM
