Results 1 to 7 of 7
Thread: Engine
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Default Engine
    Hi guys.
    Firstly, I don't want anyone saying "It would be cheaper to buy an SS...."
    What kind of cost would I be looking at to converting a VZ Executive V6 auto into a V8 manual of some sort? Either a VZ SS motor, or, Holmat do have the 6L VE for $6500....then the VE 6 Speed "TR6060" manual is just under $4K...
    Would $20K be around the mark? Or would I be looking at $25/$30K?
    Or, for the cheap path example. Comes with Engine/Trans, 104K kms, presume you wouldn't need to spend much on top of this? $5K - $10K extra?
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    vz v8 wanna be
    Sep 2010
    caloundra
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    The complete conversion would be upwards of 10k. i know of someone that has recently done it, although he is thrilled with having a V8, it did cost him a lot. He had done a bit of cosmetic work to his sv6 so i guess he didnt want to part with that.
    Im a true believer of going for what you want, but seriously, bang for buck, and the complexity of what your trying to achieve, hands down, save yourself some $$. If you want a V8, buy one in a car already, and spend the other money left over on some wheels, suspension and a tune.. cause thats probably how much you will have left over.
    Not only is it going to be cheaper, but an SS or something of that nature would be easier and far more reliable.
    Goodluck with your choice, either way, im sure it will be a lot of fun..
    Life starts at 200km/h
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    Would be wiser not to mention much cheaper to buy a t boned or rear ended ss and swap over the running gear... that way you will have all the interior and body panels for spares... would probably cost around 6-7k at auction, then you can spend the extra 13k or so on a turbo or supercharger kit.
    VZ Lumina 4sp
    May 2011
    Our ss's have been going for around 3k for a okish one....cheaper if its a stat write off. Thats the way to go lol auctions ftw
    Quote Originally Posted by Ryley View Post
    Hahaha, all you need now is a unit sticker; extra 600HP.
    SS Catback
    MACE Cold Air Intake and Insulators
    147rwkw
    Feb 2011
    Melbourne, AUS
    Quote Originally Posted by Kiddo View Post
    Damn that's cheap!! I couldn't even get a stat write off executive for parts for under 3k!!
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  4. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  5. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
