Results 1 to 7 of 7
Thread: VZ Commodore Fuel Filter Removal
    VZ Lumina Sedan
    Oct 2011
    Langwarrin, Victoria
    Default VZ Commodore Fuel Filter Removal
    Hi all. I was wondering if someone could tell me if I require a special tool to remove the in-line fuel filter from a VZ Commodore? (located just in front of the petrol tank)
    There is a special clip that comes with the new filter and I can't quite work out how it goes on/comes off.
    I don't want to have to drive the car up on ramps and go to do the job, then find out I need a special tool.
    Cheers.
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    I've never replaced it. No need till the current one breaks.. Remove fuel pump fuse (under bonnet RHS) start engine and allow to stall. Push, Squeeze the tangs on the side of the connector, then pull.. Take note of flow direction on new filter, push connector's onto new filter, replace fuse and turn on ignition (allow to prim) and start engine then check for leaks.
    Happy to show you considering that you're not to far from me (PM if you wish)
    Cheers,
    Dave
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I have used multi-grips to do all my fuel filter changes (VY same as VZ) However the connections are starting to deteriorate, so I'm going to purchase the correct tool, available in my town from Autopro. Repco has a similar tool, but it is only for the quick connect fittings, not for the filter.
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i heard those connections are pretty expensive if broken, fairly sure you have to replace the whole lines.
    Life starts at 200km/h
    VZ Lumina Sedan
    Oct 2011
    Thanks Dave, Much appreciated. Thanks for the offer, however I'll give it a go myself and if I get stuck I'll PM you for help. Once again, much appreciated. Cheers, Rodney.
    VZ Lumina Sedan
    Oct 2011
    Quote Originally Posted by VYMAD View Post
    Thanks VYMAD. What is special about the way the tool works? e.g. In what way is it different from using multigrips? Is there something that the tool disengages?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by impulsive View Post
    I stuffed the connections at both ends of the filter doing the 90k change and had to get the old filter replaced by a mechanic. I knew that the connections were only good for one more filter change so when the next one was due, I had to cut off the connections and replace them with bronze elbows, rubber tubing with clamps and use a VN style filter. There are other threads already about this
    The lines are not dear to replace but the effort to get the old ones out and new ones in is significant. I was quoted about $11 trade for the line from the tank to the filter on my VY and $23 for the steel pipe from the filter to the engine bay. Once I had a good look at the work involved, my first thought was "F*** that". Much simpler just to replace the connections and use the (cheaper) VN filter.
  1. Fuel Filter VP Commodore
    By sossposs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2010, 09:39 AM
  2. fuel filter ve commodore
    By rs20002006 in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-09-2010, 09:27 PM
  3. Fuel filter removal problems
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-01-2010, 02:53 AM
  4. Fuel Line removal tools for Fuel Filter
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:56 PM
