Results 1 to 16 of 16
Thread: vz ss clutch
    vz ss
    Sep 2011
    Default vz ss clutch
    Hi guys
    when my vz 5.7L 6sp man is under high revs (4500rpm+) then chaining gear the clutch sometimes drops a bit lower then the usual spot when releasing the clutch and other times a bit higher then the ussual spot if you get what i mean?
    This Only happens under higher RPM. when driving it like a nun its perfectly fine?
    Ive only recently purchased the car so i still have the dealer 3month warranty, just wondering what you guys think?
    VY SS
    May 2011
    Auckland
    If you can get a clutch out if them do it. They're expensive.
    I would guess they'll say a clutch is normal maintenance though
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    unless its a direct gearbox issue, i'd say no just like m1lky...
    it would come under a wear and tear item
    Chev badges are an instant fail
    vz ss
    Sep 2011
    Im not trying to get a new clutch out of the dealer. was just wondering what the actual problem might be - besides "just replacing the clutch", unless of course thats what is needed.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Please explain "clutch drops a bit lower"
    Edit: all good, I understand.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    maybe have your mech change the clutch fluid, see if that helps
    vz ss
    Sep 2011
    basically changing up a gear at high rpm (4500rpm+) once i changed the gear (eg from 2nd to 3rd) once i release the clutch it doesn't return to the usual point when the clutch is out, then when i change to the next gear (eg 3rd to 4th) it returns to the original point. make a bit more sense?
    I think ill get the dealer ship or my mechanic to bleed the clutch & change clutch fluid as it looks a bit discoloured. any other things to check?
    vz ss
    Sep 2011
    VZ SS
    Nov 2011
    wanneroo
    Hi, I have had this problem with my car, my mechanic said that the standard clutch in the VZ has a spring in the assembly that causes it to do that, im sure if you rang any of the performance shops they would explain it better, what I did was upgraded the whole thing, lightened chrome molly fly wheel, organic pressure plate, new clutch cylinder thing, and replaced clutch fluid, cost around 2 Grand to do but the difference is amazing.
    vz ss
    Sep 2011
    Quote Originally Posted by VZSS View Post
    Hey mate, sorry it took a while to respond - didnt realise any body had responded after my last post lol.
    If its something todo with a spring which is what it feels like id rather replace then then do the whole clutch upgrade as im a bit strapped for cash atm
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    meh I wouldnt worry about it, mine does it occasionally and its held on for 170,000kms so far and still doesnt slip. Thats with around 315rwhp.
    Dont waste money replacing it till it fails ie slips or destroys itself or you do some serious power upgrades.
    Silver Certified.
    vz ss
    Sep 2011
    Quote Originally Posted by RiCeY View Post
    Cheers mate, clutch doesn't slip or shutter at all, so that's why I'm wondering if it's only a spring or something minor to replace
    VY SS
    May 2011
    Auckland
    The spring is built into the flywheel.
    Look on you tube for dual mass flywheel it will explain how it works.
    http://m.youtube.com/index?desktop_uri=%2F&gl=NZ#/watch?v=YnaXB8q3uzQ
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by m1lky View Post
    YouTube - Broadcast Yourself.
    The V8s do not have a dual mass flywheel.
    Silver Certified.
  15. #15
    vz ss
    Sep 2011
    So it could be something to do with the spring inside the fly wheel or the fly wheel its self :S
    I cant view youtube vids from work will have a look when i get home.
  16. #16
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Did u miss my post?
    Silver Certified.
  1. VX Clutch - How worn is this clutch..??
    By RvtRvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2011, 12:22 AM
  2. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  3. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  4. [VIC] WTB: vn v8 clutch fan
    By Noy in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2009, 12:34 AM
